Question about Ulead Videostudio 8 for PC
Audio out of sync
Can record ok but on playback the Audio is out of sync. I am using Easycap to capture videos from my VHS
many thanks Jane
  • 4 more comments
  • Lovevideo Feb 27, 2008
    Audio is out of sync with the video
  • schneeschmid Apr 24, 2008
    I also have my audio not in sync with the easy cap video. It does not matter, if I use the internal microphone or the audio in of the Easy Cap stick. With different recording tool audio stays out of sync.
    Any ideas?
  • jimmy40 May 28, 2008
    same problem sound is like slow crackling noise, why??? tried internal speaker , no go, any other solution
  • Anonymous Sep 02, 2008
    fghfghfghfghfghfg
  • Anonymous Jan 02, 2009
    Same problem for me using Easycap. At the start of recording from VHS everything is ok, but pretty quickly the audio starts to show before the video, which increases throughout the recording until they are totally out of sync. Any ideas?
  • chookybirdy Jan 02, 2009
    Same problem for me. When recording from VHS using Easycap things are fine for a few minutes, but quickly the audio starts to appear before the video, which gets worse as the recording continues until they are completely out of sync. Any ideas?
  • 3 Answers
You may want to put the audio into the microphone-in of your laptop and make menu selections for audio via that line-in port when recording. I found as well that the audio sync was out of whack when trying to have it go with the video through the EasyCap..
Posted on Jan 06, 2008
Thnx for the solution JohnJN. The audio is now in sync. Was looking for this solution for a long time. I hooked up my gamecube, and start trying to play Zelda Twilight Princess. Normaly i had to reboot the media player classic after about 20 minutes because the audio was realy bad out of sync then, but now, i played the whole night long, and no problems!! Thnx for the solution, i ow you big time!
Posted on Jan 20, 2008
I got a idee for myself. Try the import port of your sound divece (normaly lightblue) with some connectors. I got surround sound after some modification of the Johnjn idee! (4.1).
    Problem Solver:
  • 3 Answers
If the Audio seems correct at the start, but gradually gets more out of sync as the job progresses, it might be that the frame rate is not correct, and as a result, the video is ending before/after the audio.
Posted on Sep 07, 2008
Windows7 64bit & EasyCap directions
In my experience with the Easycap software the quality of sound & vision is very poor. My recommendation is as follows:
1) Use windows movie maker instead to capture video.Use the 2M byte/sec capture rate. Make sure the box for "make video clips" is NOT selected - you probably don't want your vid chopped into little bits.
2) In my experience USB audio is rubbish on these devices, so instead connect your PC or laptop audio LINE IN to your sound source. Don't forget to set sound source in RECORDING section of Control Panel Sound devices to Line In instead of your Easycap (which the Easycap drivers would have preset it to by default).
Good Luck.
May 17, 2014 | DekCell EasyCap USB 20 Video Capture...
Hi There! I have an old camcorder, model is a JVC GR-DVL150E . I would like to know if its possible to transfer my footage from the tapes on to my PC and save it to discs! if so how do i do this and what...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 26, 2011 | JVC Video Cameras
I am using a Samsung model#SCA30 camcorder to playback my movies,to the easycap.My problem is that it will only playback in black&white,can I get color?
No . In the screen it will come on Black & white mode only. But when you make it in disk & play on CD player then it will come in color.
Jan 25, 2011 | Samsung Video Cameras
U lead video capture
It's either something to do with your PC sound settings. Maybe the recording level for sound is set to low or switched off. Or it's in the Easycap software where the audio is switched off.
Jun 11, 2017 | Ulead DVD Workshop 2 for PC
EasyCap usb adapter sending images only from vcr. No sound.
while i preview mode there is no sound only image. when you record then playback sound is there.
Sep 16, 2008 | Ulead Videostudio 8 for PC
Audio in EasyCap/VS10
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly.
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound. Although I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Hope this helps!
Mar 07, 2008 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
3,996 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
