Question about Sony Playstation 3 (PS3) Console
I've been playing online with my ps3 for years now since it first came out. i connect with the ethernet cable my system came with and it has always worked but last week i pluged it in like usual in my internet box to the ps3 and it told me your "ethernet cable is not connected" which clearly was. so then i swtiched sides and it will not work now the ps3 just wont read my ethernet cable so i cant play online..... can plzzzzz someone help i dont know what to do??????? thanks
  • Sony Master
  • 1,527 Answers
Hello have you tryed another ethernet cable also turn the power off at the router take the lead out at the back of the router there should be reset button hold this in for 15 seconds re plug in everythink in hopeful it should work good luck
shaun
Posted on Jul 31, 2009
My ps3 freezes when i try to play online
Alexander, you left out some important info, so this is just guess work. Can you play games fine off line? If yes, then you are having a connection issue. First, WIRED? or WIFI? Connecting with the Wireless, will alwayes have a weaker signal, and lower bandwidth(mbps) Than if you are (HARD WIRED). Try using a CAT5 Ethernet cable and wiring directly into your ISP'S modem. When you do a speed test on the system, you are looking for around 10mbps or greater download speed. If you can't get at least 10mbps, then you will have system lags and hang-ups.
Mar 16, 2014 | Sony Playstation 3 (PS3) Console
Ps3 error code 80029020
Make sure UPnP is enabled on the PS3 and Router.
Place the PS3 in the DMZ of the router or find the appropriate ports to forward to the PS3's connecting IP (set to static in the PS3 if you have it setting dynamicly in the PS3 for either)
If this does not help, do a forum search there are a ton of answers for this on on the Network board here.
Feb 23, 2014 | Video Game Consoles & Games
Do we need ethernet cable to have ps3 work on tv?
no you do not need it to play but you need it if you want to play live. (online)
the ethernet cable is for getting online through wifi,lan or cable ty...
mery xmas and vote for me if this helps
Dec 25, 2010 | Sony Playstation 3 (PS3) Console
Ethernet cable connection to PS3
maybe your ethernet cord might need to be replaced
Jan 11, 2010 | Sony PlayStation 3 40GB System
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
Ps3 not working
you have to change settings wireless connection ....then scan for connection http://www.youtube.com/watch?v=NC7aPylbI3M for step by step video hope this helped yea
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
Resident Evil 5 PS3 Won't work online
Keep the the ethernet cable connected and install the update. It is required to play online.
May 06, 2009 | Capcom Resident Evil 5 for PlayStation 3
When playing ps3 game live i get kicked off the games what is going on
Are you running the live game play through the internal WiFi card or a wired Ethernet cable? If you can try hooking up an Ethernet cable and it solves the problem, you are getting interference from something and you'll have to move the PS3 closer to your router or just try to keep it on the Ethernet cable for online play. That's what I use because it is much more reliable and much faster than WiFi.
If you are running with an Ethernet cable and you are still having problems, the problem may not be with your PS3 but with your router or internet connection. Try moving the cable to another outlet on the router. Check your network settings on the PS3 amd try to set up the network to automatically detect settings.
Depending on the game, you may be kicked off by other users in the game. I've had that happen a couple times because everyone's a critic.
I hope this helps. Good luck and have fun online! Don't forget to rate! Thank you!
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 internet problem
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
MY PS3 WONT CONNECT ONLINE`
you need a crossover eathernet cord its diffrent then a regular eathernet cord
Aug 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
