Question about Refrigerators
Maytag MZD2766GE, the compressor does to attempt to come on. Any suggestions on where to start. It is about 3 years old.
    Scholar:
  • 117 Answers
The first thing to do would be to make sure the defrost timer is not stuck in defrost mode.Turn the keyhole with a screwdriver clockwise about one quarter turn .Next try jumping out the thermostat .(Unplug unit prior to doing this of course.)If the compressor comes on then you have a bad thermostat. If it does not come on then the problem will be with one of the components on the compressor itself. Hope this helps
Posted on Jul 30, 2009
Maytag MZD2766GE refrigerator side is not cooling well. Freezer side has no problem. Where are the coils for cleaning? Any other ideas?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Maytag MZD2766GES Side by Side...
My Maytag Perform refrigerator, about 6-7 years old, doesn't freeze (upper) or chill (lower). Any suggestions what I can do?
Check compressor and fans to see if they are running . If compressor is not running is it clicking every few min or hot.
Nov 18, 2010 | Maytag Refrigerators
My Maytag MZD2766GE dispenses water but does not make ice
check water valve, also your water line for ice maker could be frosted that happen always, but reason is bad water valve....
appliancesrepairla.com
Jul 01, 2010 | Maytag MZD2766GES Side by Side...
Mzd2766ge, is running but will not get cold. you
You have either a bad start relay/overload combination (12002784 - if the first two numbers in your serial number are from 10 to 26) (12002794 if the first two numbers in your serial number are 27 and higher).....or you have a bad compressor.
Dec 30, 2009 | Maytag MZD2766GES Side by Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Frig. is 5 years old - Not cooling - Buzzing clicking sound
Sounds like the compressor or start relay have went out.
For any recall info you would need to give the full model and serial to the Maytag.
jim
Jul 27, 2009 | Maytag MFD2560HES Bottom Freezer French...
26 Cu Ft Side By Side Maytag Refrigerator: Relay Failures
you have more than likely got a bad compressor it is pulling to many amps you need to replace the compressor
Jul 12, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
MAYTAG MZD2766GE SIDE BY SIDE
Mine kept doing the same thing- the flap between the freezer & the frig is getting stuck. I finally just broke mine off & left it that way. Now the frig is really cold, sometimes things partially freeze- but that is better than going rotten. I now have a section under the water/ice dispense tray bubbling/peeling the white paint off. Mine is 6.5 years old & out of warranty, so I'm searching for a way to repair this problem. Any suggestions?
Jul 11, 2007 | Maytag MZD2766GES Side by Side...
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
It's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself. If your compressor has a label on it with a blue indian head symbol, then you're out of luck as that brand pretty much sucks and is destroyed by heat. It would mean a new compressor and then you'd be lucky if the new one even worked from the factory. Avoid those Tecumseh compressors at all cost.
Jan 07, 2007 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
