Question about Kenmore Washing Machines
Agitates loudly and moves alot - Kenmore Washing Machines
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Agitator is frozen
my machine modelis AW-9770s
Dec 03, 2013 | KitchenAid Washing Machines
Makes a loud noise when agitating and wont move
OPen the center stem and then reach in and remove the next cover there should be 3 tear shaped rubber thingies that control the agitator moving in agitation mode. Change those if they show wear
Jul 12, 2011 | Magic Chef CAV2005A Top Load Washer
I have 7.5kg whirlpool 6AL that make alot of agitation noise, is that normal?
Thanks for choosing FixYa and welcome. It is normal to have a little bit of noise but not loud noises. The motor drive controls the agitation. You may want to check the motor out. The transmission may be messing up or it may be something else. Have you had any issues with the machine since the noise is occurring?
May 04, 2011 | Whirlpool Washing Machines
At the spin cycle a loud noise is made with the machine shaking alot....spin cycle doesn't work
sounds like the agitator motor has broke loose from the agitator just take apart and see whats broke and it shouldnt be a hard fix
Feb 25, 2010 | Dryers
Our kenmore elite washer makes a loud loud noise when spinning and the tub has alot of play from side to side when not running. Does this maching have a nut on the bottom holding the tub in place?
You can remove the agitator to see if it has a nut holding the tub on, but from what you are saying the transmission bearings are worn out. Loud noise and side to side play would indicate this. If the agitator does come off you can see if it has a nut that will tighten the tub down. I have never seen one as most are all one section tub to transmission. Keep me posted on what you find.
Sincerely,
Shastalaker7
Feb 04, 2010 | Washing Machines
Noisy when agitating. has not been moved
Noise comes when some part of the moving part is getting collided or getting stuck somewhere. Try cleaning the wash cycle and the rinse drum. It is the only cause of noise. Thank you, Sir to visit Fixya.
Sep 17, 2009 | Washing Machines
Agitates loudly when in use
It souds to me that you might have some bad agitator dogs. To test this problem, grab the agitator and replicate its motion during operation. If it moves easily in both directions, or makes the sounds you're describing move ahead. If that test passes, unfotunatley, you might have a transmission or tub bumper problem. not too bad, but more involved.
Begin by taking the very tipy top of the agitator off. You'll see inside a plastic piece you can pull right out. Next you will need a 9/16 or 11mm socket with extention. Remove the bolt and pull the top half of the agitator out, tip it upside down to remove the dog carriage. See those four small plastic things? Those are them. They're very cheap and redily availible. Reassemble, and enjoy your laundry! Let me know how things go.
Jan 29, 2009 | Whirlpool GSC9455 Top Load Washer
Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Jan 28, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Agitator stopped moving back and forth
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Feb 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
