Question about Health & Beauty
Quickie aspire wheelchair chair works when plugged into AC, won't work on DC
  • 925 Answers
Posted on Feb 14, 2018
  • 16 Answers
SOURCE: Manual wheelchair Hard to PUSH
Pull off the Big Wheels and see if you have Hair Wrapped around the Axel part of the wheel, sometimes when I used to have a manual wheelchair hair would wrap around it. If not, then it really could be your tires, especially if they have treads on them, you might have warn down the treads making it harder to push, so check both, if your treads are low, then you need new tires, you can either call the person who helped you get the chair, like a wheelchair Specialist or even try your local bike shop, I've gotten tires from them before, they aren't as good as the ones I get from my Wheelchair Specialist - Hudson Home Health Care, but they at the time were better than nothing.
Posted on Mar 06, 2009
  • 68 Answers
SOURCE: Norcold DE704D won't switch to AC
http://www.thetford.com/LinkClick.aspx?fileticket=slRtJeja7H4%3d&tabid=497&mid=1316
This link will help with testing and resolve your problem. Can not resolve without these tests.
Thanks for using Fixya
Jerry
Posted on Mar 30, 2009
dromtonpa
  • 40 Answers
SOURCE: QTRONIX joystick for a Quickie P200 wheelchair diagnostics
Any reputable dealer will have a PnG or Qutronix programmer that plugs into the chair in order to program the profiles. This dealer obviously does`nt know that. Call a different dealer.
Posted on Apr 01, 2009
  • 32 Answers
SOURCE: Aspire Quickie Battery Charger
most chargers have an external or internal fuse, try replacing.
Posted on Jul 13, 2009
  • 177 Answers
SOURCE: I have a Hoveround MVP 4 power wheelchair. I purc...
Hi. your problem could be a couple of faults. Have you checked that both tyres have the same pressure in them? Problem could also be a faulty motor or brake unit. When these motors have done a few years work they build up carbon and copper dust from the brushes and the commutator. the motors can be tested for this if you find a clever serviceman. The motors should also be tested to see if they are both drawing the same current ( amps ) when in use. In answer to your last question, the answer is probably no. Good luck. Neil.
Posted on May 28, 2010
I have a quickie electric wheelchair. The right axle was locked up. I turned the power on and now all I get is a flashing light. The batteries are new and fully charged. What could the issue be? The home...
The right motor will need to be replaced. What reason did they give why Meduicare wouldn't pay for repair If the Aspire is your only chair then Medicare will pay. If you have received a new chair since the Aspire then Medicare will only pay for repair to the newer chair. You can contact a repair service other than the home Medical to get the chair fixed. You can contact Roadrunner Mobility @ 1-800-467-2668 for repair Hope this helps you
Jun 26, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Trying to obtain a manual for a power chair, Sunrise, Aspire Quickie?
lundsuzy goto: sunrisemedical.com At the home page in the product search box in the upper right type in "Aspire". When that page comes up click on view details then the next page will list owner's manual there your manual will come up and you can print it
Sep 17, 2010 | Quickie Wheelchairs Quickie Aspire Power...
After two or three minutes of travel, the power
You got some bad batteries or your charger is not working. If Medicare purchased the chair contact Repair Xpress at 1-877-581-3733 Medicare will pay for most of the repairs
Jul 25, 2010 | Quickie Wheelchairs Quickie Aspire...
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Do they still make the Aspire Power chair ?
You can still get parts. The Aspire is an older model though
Jun 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
I have a quicky power chair, i think its an F-35 b...
I think you have locked your controller, or put it in "sleep mode". Turn on the chair again and push the joystick forward, then to reverse, then forward again and release. It should fire up. Let us know if that worked.
May 21, 2010 | Quickie Wheelchairs Quickie Aspire Power...
How many batteries do I need for the chair
You will need two, sealed lead-acid, deep-cycle batteries. Go to a battery shop, not Sears or such and make sure you tell them they are for a power chair. Most chairs take U1 batteries, but larger chairs take group 22, and the biggest chairs use group 24. Mini-chairs vary, so take the batts in with you.
Dec 24, 2009 | Quickie Wheelchairs Quickie Aspire...
When you turn the chair on the light just binks
If it is just one red light blinking, then your batteries are below the level necessary to power the chair. Charge and see if they come back up, or replace if they won't.
Oct 23, 2009 | Quickie Wheelchairs Quickie Aspire Power...
Apr 12, 2009 | Quickie Wheelchairs Quickie Aspire Power...
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
