Question about Blade Saws
How do I replace the blade on a Pro-pulse 10" compound mitre saw. I can't get the safety guard off to reach the blade bolt.
  • 10,314 Answers
There are several you tube videos for different brands. You may find one similar to yours.
Posted on Feb 14, 2018
Testimonial: "Unfortunately I can't find any for ProPulse."
  • 1 more comment
  • Lisa
    Lisa Feb 14, 2018
    Unfortunately I can't find any videos for Pro-pulse.
  • Lawrence Oravetz Feb 14, 2018
    There may be something similar with a different brand name but still the same saw.
  • Lisa
    Lisa Feb 14, 2018
    No luck so far, unfortunately.
4 Suggested Answers
  • 12 Answers
SOURCE: Mastercraft 10" compound mitre saw model #
Mastercraft's toll free help line is 1-800-689-9928. They will need your product code and are very helpful at getting you replacement parts.
Posted on Aug 31, 2010
puertobori
  • 7733 Answers
SOURCE: blade guard for Ryobi 254mm Slide Compound Mitre
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need a replacement blade guard for my EMS 1100 A
Is this the Ryobi EMS2026SCL?
What is the brand name?
I am just trying to help you here but you should be able to get parts through Bunnings Warehouse in AU or NZ. I could care less about the money.
I think the 1100 number is for the Laser only. (
Kelly
Posted on Sep 10, 2011
Blade guard for power craft compound mitre saw WK 1200
Lows, Home Deport, Ace Hardware, Tractor Supply, Target, Wal-Mart. Kmart, about any major store. Harbor Fright. Etc.......
Jun 23, 2013 | Saws
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
Mastercraft 10" compound mitre saw model # 55-6895A , broken plastic safety guard , can it be replaced serial #W034453
Aug 20, 2010 | Saws
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do you replace the blade on as Protech 8 1/4 inch compound mitre saw? i can't get the blade to stop spinning and i can only get to one side of the attachment bolt.
there should be a spindle lock on the opposite side of the blade bolt,, make sure that when you replace the blade that you install the flanges correctly and if there a spacer that it is in place.
Dec 22, 2009 | Bosch 12" Compound Miter Saw 3912
I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Apr 10, 2009 | Makita 10" Miter Saw LS1030N
I have a 10"DELTA Miter Saw and need to change blade. Please describe how to remove and replace blade. Thanks
Without a model number I cant look for this saw, but if it is like the other mitre saws that I work on, the lower guard should have a bolt holding it in place, loosen the bolt so you can move the guard and the blade bolt is usually LH thread, on the backside of the gearcase by the blade there should be a spindle lock, rotate blade until it locks and then remove bolt. If your saw is different please give me the model number and I will pull up a schematic and look at it.
Jan 16, 2009 | Saws
Saws Logo
77 people viewed this question
Top Blade Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Blade Saw Expert? Answer questions, earn points and help others
