Question about Toshiba (K000823110) Motherboard
Tecra M3 won't boot, hdd light comes on then off.
Initially I started getting weird display (lines down the screen etc) which I have found a plethora of posts about the video cards on these babies. Anyway I tried removing the driver, and it worked OK on just vga but of course very slow scrolling. Reinstall the driver and it'd boot and windows runs OK for a few minutes and then colourful screen and no response at all. Had to power down.
Well this got progressively worse until now I can't even get the thing to boot. I've removed ram and re-seated it. Tried other known good ram too. When I power the unit up the hdd light comes on but it doesn't spin up, and after a few seconds that light goes out. If I leave it on for another few seconds the fan starts up too.
I know my hdd is OK, can put it in another machine.
  • scottjellis1 Jul 31, 2009
    Thanks Geekman - to answer the first part, yes I can boot it in an identical Tecra M3 and it works. I suspect my laptop simply isn't getting to the windows boot stage, although I can't be certain with no display showing. have tried an external monitor too. No go. If my hdd is fine, then does this suggest main board issue (or at least the video component which then = main board anyway) Oh and thanks for the speedy reply!
  • Toshiba Master
  • 32,281 Answers
The hard disk can be installed in another computer, but it won't boot up and run unless the computer is the same make and model with the same devices as the previous computer.
If it is not then you need to do a fresh Windows install to get a working computer.
What you can do as an alternative is to install the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Posted on Jul 31, 2009
Tecra m3 screen
my dvd door wont open
Dec 08, 2012 | Toshiba Tecra M3 Notebook
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
Toshiba tecra M3 wont start. Upon startup it shows a black screen and says problem loading operating system
download form bootdisk.com "XP Boot" and burn to cd in an .iso (bootable) format.
boot from the cdrom (you may have to go into BIOS and look for a "boot priority" option to allow you to boot from cd, to acess BIOS, hit "escape" and then either "F1" or "F2" as soon as you turn it on). run fdisk /mbr from the XP Boot cd. with this tool, try to repair the mbr. if that does not work, you need to use this tool to erase the mbr and reinstall windows.
Nov 06, 2010 | Toshiba Tecra M3 Notebook
Hi, I have a toshiba tecra m3, it boots fine and runs fine but the screen is black, if I close it and open it again the screen comes on for a couple of seconds and goes black again. Any thoughts would be...
Try connecting it to an external monitor, it could be that your laptop is either set to display through an external monitor or it could be set on a screen size too large for the laptop screen.
Oct 18, 2010 | Toshiba Tecra M11S3410 I3330M 213G 2Gb...
No Screen display on tecra m3 laptop
if you go into safe mode (F8) on boot-up, does the graphics show up?? If so, it's the graphics board/chip on the MB. I have one and have the same problem - no amount of loading drivers, re-install BIOS, etc. would help. sometimes it works, but most times when you start up, shows the Toshiba logo, and once windows starts, goes to a black screen.
Oct 02, 2009 | Toshiba (K000823110) Motherboard
Toshiba Tecra M3 will not boot, no video, pwr + hdd light on
If not beeps you didn't hear then it's your Motherboard. But, there other problems aside on it.
Laptop maybe have a problem with Power Connection, see to it that your Laptop Power Adapter is supply exact voltage to your Laptop, low voltage power also may cause not to give power your laptop sufficient, if it is does.
And if none of this then it's your Motherboard.
Hope this tip might help you.
Sep 23, 2009 | Toshiba (K000823110) Motherboard
Toshiba tecra m4 tablet pc screen problems
Video driver update try updating your video driver
Jun 16, 2009 | Toshiba Tecra M4 Notebook
My toshiba tecra m3-s336 wont boot up
boot from bootable cd and when prompted press F2 to recover using recovery cover. you will enter to console and type on the console :
chkdsk /f /r
after finished reboot your computer
Mar 25, 2009 | Toshiba Tecra M3-S336 (PTM30U02M00L) PC...
HDD cange, boot error
is this the original hard drive
for boot options while in restart constantly press F7 a menu will come up high light your boot choice
you may need to run windows on the hard drive again
Jan 20, 2009 | Toshiba Tecra M2-S730 Notebook
Answer to your question
You will need to get into the bios, and set the CD drive to boot before the hard drive. Since your in this uncompromising loop, remove the hard drive, then start the machine. It should go to the initial Toshiba screen and you will see the prompt on what to press to get to the bios, or utility set up. Once your in the bios, find the boot order and set the CD drive over the hdd. Then put the hdd back in, the recovery or operating system disc in the CD drive, and start the machine. It should now boot from the disc. At this point you will want to do a system repair. If the repair doesn't take, then reformat the hdd, and install a new operating system. If the hdd will not format or you have any issues during or after the install, then the hdd has failed and will need replaced. If you need any futher aststance, just ask.
Aug 28, 2008 | Toshiba Tecra M1 PC Laptops
Toshiba (K000823110) Motherboard Logo
610 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
