I HAVE A DELL INSPIRATION 1525 AND AND BOUGHT A NEW 9 CELL BATTERY BECAUSE IT WAS NOT HOLDING CHARGE, EVEN WITH THE NEW BATTERY ITS DISCHARGING WHILE PLUG IN AND IN USE WHAT MUST I DO.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
There are a few possible problems. First of all, check out whether it works fine with a different adapter. If it works, then replace the adapter. If the same problem persists with a different adapter too, then try this. Shut down the laptop and carefully remove the battery, check whether any dust particles there, clean it and put the battery back and try charging it. It should work fine. You have not mentioned whether your laptop lasts for more than 1 hr inspite of it saying the battery level is 40%, if it lasts then, there is no problem in your laptops battery.
Posted on Jul 30, 2009
Battery Wont Charge Past 65%
There is a short-circuit happened at your laptop or the laptop charger.
Aug 12, 2013 | Computers & Internet
I bought brand new laptop dell inspiron 1525 and now battery looking damage in less then one years. I need some reliable source where i can purchase quality battery with reasonable cost
I have used a web site for purchasing several replacement laptop batteries, it's called richbattery.com. Both the branded and richbattery.com batteries come with same warranty, both are new, both are the same rating, money back guarantee and I would bet both come from the same factory in China!!! . Try this http://www.richbattery.com/New-Battery-for-Dell-Inspiron-1525-7200mah-9-Cell-Laptop_p_58649.html i hope it helps
Jul 10, 2011 | Dell Inspiron 1525 Laptop
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
I have a Dell Inspirion 1525. The Battery would not charge and the light would flash orange. I bought a new one and upgraded from a 6 cell to a 9. Now it says plugged in but not charging and the batt light...
Firstly, i suggest you try to use the charger with a similar laptop to see if it will charge it.
If it does, it means the charger is still very much good.
And as for the battery you change, it will be better for you you to check the voltage rate on your charger and the voltage rate on the battery because it is very possible, the voltage rate of your charger might not be able to power your new battery.
The voltage of the new battery might be higher than what the battery could power, so you might need to get the same voltage rating of charger for the new battery.
**** you can still test the charger with a similar laptop to be sure the charger is still good.
Take care.
Apr 19, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 battery problems.
try removing the battery and turn on your laptop, then while laptop is on, slide in the battery.
Apr 18, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Where I can find a battery for Dell INSPIRON 1525 ?
Dell 9-Cell Battery : Here
Dell 6-Cell Battery : Here
If I was helpful, Kindly do Rate!
Regards,
Waqar.
Sep 03, 2009 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 and it wont charge
If possible could you check output voltage of the charger with a multimeter? If you can get output voltage, then might be something wrong with laptop battery charging circuit. Contact Laptop Repairing Engineer.
Regards;
Hassan
Aug 04, 2009 | Dell Inspiron 1525 Notebook
Battery will not charge
clean the battery charging terminal from your laptop battery compartment sure it will charge now.
Aug 02, 2009 | Computers & Internet
Latitude L400 new battery not working?
u should charge new batt for about 6 hrs and then 2 to 3 hrs
Dec 20, 2008 | Dell Latitude L400 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
