Question about Hoover Vacuums
How do I replace tank latch on Hoover SteamVac 59149
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
SOURCE: recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Posted on Apr 04, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
  • 240 Answers
SOURCE: My Hoover SteamVac Max Extract 77's dirty water
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Posted on Jan 22, 2011
My Hoover Steamvac won't suck. I checked the front door thing on the dirty water tank and found a crack where the bottom of the door meets the tank. Would this stop it from working?
From your description, this would certainly need to be corrected, and yes may be the problem. Also, check the recovery tank lid to make sure that is on and latched properly. Ensure the round tube that is under the recovery tank has the gasket seal installed.
Sep 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac does not **** up the water
There are two common situations that can cause lack of pick-up. First is that the lid is not properly attached to the recovery tank. Make sure it is latched in back and snapped in place in front. The second common problem is that the duct on the front of the dirty water tank is missing. There is a plastic duct about the size of a slice of sandwich bread which slides into the front of the tank, and is removed when the hose is in use. A less common problem is that the large round rubber seal that the tank sits on has fallen off the suction tube on the motor cover.
Feb 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
How do you remove the water tank
At the top of the water tank is a latch. Pull down on the latch and tilt it out and downward.
Best regards, --W/D--
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5905900
The proper way to install the reovery tank lid is to attach the front such that it catches the tank and then lowered to snap in place in the back
Mar 09, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Frist time useing the product. It is not sucking the water.
Make sure the front of the tank is latched. This is a common problem as one side needs to be latched before the other.
Check that the side of the tank with 2 places to latch on is actually latched and then latch the other side.
Dec 11, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Oct 08, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
