Question about Miele Coffee Makers & Espresso Machines
Wiring diagram for miele cva 4075 - Miele Coffee Makers & Espresso Machines
  • 1 more comment
  • Luigi Marazzi
    Luigi Marazzi Feb 14, 2018
    Hello Mark
    thank you for taking the time, your answer and links. it is very much appreciated.
    We installed the unit in 2007 and have made on average 8 cups a day. clean it descale it as indicated.
    The unit required one service call when new and nothing since. Of late it has stopped grinding coffee, grinder would spin but no coffee ground. Upon dismantling the unit, the grinder and chute were found to be blocked with hardened coffee ground. The grind unit and machine have been thoroughly cleaned and reassembled, save the connections to the grinder motor, a red power wire with a female spade connector and a thinner white signal wire with a smaller male spade connector. I cannot find vacant slots to connect to. I need a wiring diagram, but have not been able to
    find one anywhere. Cleary I did not make a note or take a picture, it seemed so obvious at the time..
  • Terry
    Terry Feb 14, 2018
    Additional information for this model:
    http://www.cagrimmett.com/justanswer/cva...
  • Luigi Marazzi
    Terry, I do have that manual, unfortunately, it does not include a wiring diagram. thank you
    Master:
  • Miele Master
  • 791 Answers
First, I'm not a Miele tech. I recommend contacting your vendor or the MFR for support. Check your warranty.
*** the following is for information only ***
* I've worked on table top "Super Automatic" brewers and not a fan of these small units. Similar to the larger Supers, these are the home/office style units. But all have the same problems as the larger professional units. They all require daily maintenance to be performed in order to maintain it. The reason is that these Super Automatics try to replace a Barista. It takes time, training, and lots of practice to become a good Barista. But now with a touch of a button, this 'Robotic machine' will make your favorite Latte for you. But you must keep this robot clean and serviced in order to keep producing coffee (especially milk products like Latte's)
* If you haven't opened up the machine, here is a link;
https://www.bing.com/videos/search?q=for+miele+cva+4075&&view=detail&mid=B3EFF641EE5260CB49EBB3EFF641EE5260CB49EB&&FORM=VRDGAR
* following this link will also get related vids that may take you to the section your looking for. Be aware that the most likely cause of a problem is coffee grounds, water spills, and old milk getting in the wrong place and needs to be removed to function correctly.
* There are 2 basic systems in the machine for the water portion: Main heater for coffee brewing and steamer heater for the steam wand.
* Whole bean system has; Hopper, Grinder, Volume doser and/or timer.
* Group system compresses the coffee, doses a volume of hot water, then disposes the dregs or 'puck' This is usually a mechanical system with motor and gears.
* There may be an additional steam heater system if there is a Coco/hot chocolate option.
* All Heater systems have a pump (usually vibration), Heater, Thermostat(disk), Thermo fuse.
* Super Automatics always have a digital component to them. Many have options that require not only the correct PC board but also the correct PROM installed (internal programing). Most MFR's will only provide the block diagram of a unit with only a layout of where the cables attach to the PC board.
* Table units have many more sensors than their larger brothers which only check on water temps and how many pucks in the dregs drawer. Table units check the bean level, ground coffee, water level, water temps, group compression(by position), dregs level, panel doors, drip tray present, milk temp(an option), and others that may be on the CPU board as a time out or current usage. Some sensors are physical like a temp probe or a simple micro switch which are easy to find and locate by following the wires. The PC board is another mater. I suspect the MFR has a plug in unit that tests all the functions. I've used another 'good working' unit to swap test the PC boards and plug in parts. But found that PC boards have PROMs that differ from date of MFR and version. So a board may work in one version but not in another.
* Check out the you tube vids as many have come across the common problems. You will note that most are related to cleaning (or the absence) the machine. The other problem is "Opps" and walking away. People will pour stuff into the machine thinking "I thought that's where the milk goes?" or "I wanted a coco, not coffee."
* Air bubbles in the water line(s) from not re-filling the water tank. May require removing the water hose to the pump or detaching the pump from the heater to allow water to flush out the air. Restarting the machine several times may push out the air.
* Final, call vendor for help and service (if available). When I worked on these machines., these units had been swapped out by the seller whom replaced them with newer units to satisfy the customer (Hotel). The seller asked an espresso service company (us) to take a look at them figuring it's cheaper than sending them back to the mainland USA (I'm in Hawaii). So your getting the idea how hard it is to service these units.
* Once operational. Follow the daily maintenance. (and keep a look out for "Opps" people.
Aloha, ukeboy57
Posted on Feb 14, 2018
  • Mark Cheong
    Mark Cheong Feb 19, 2018
    Luigi just replied with additional information. Clogged with coffee 'fines' (dust) and had to take apart wires to grinder motor. Unable to find where they go. This happens to me all the time. When I don't have a diagram, the next best thing is to assume your the factory worker that has to put it together. How would you lay down the wires so they don't get in the way. They must also reach the location of the plug or connection. Try to lay down the wire in various positions and see if there is a connection point nearby. Another clue is the type of connection. Does it fit? These machines usually use a DC low voltage motor so crossing the wires will show up as a reversed grind. Though you could probably just check with a voltmeter to tell which is + or - An AC motor would not matter. The control/sensor wires are usually very thin wires where as the motor wires will be a heavy gauge or thicker wire with heavy insulation. Final; 2007? wow, your lucky to have this unit running at all. Most of these mini machines last 2-3 years at the most. Ceramic burrs, plastic parts, tiny heating chambers. tend to wear out quickly. So you must be doing something right. If this unit is still running, then I suggest you keep it up but double up on your maintenance frequency. Daily flushing on last brew goes a long way. Frequent checks for accumilation of 'Dust Plugs' and loose dregs will keep the inner works free of debris. There are a lot of vids on how to clean and lubricate, which should be done frequently (monthly). Aloha, ukeboy57
  • Luigi Marazzi
    Luigi Marazzi Feb 20, 2018
    Hi Mike
    I was able to source a wiring diagram from another source, Miele was no help in that regard. The unit was dismantled cleaned and now all good thank you for your input and follow up
    Best
    Luigi
3 Suggested Answers
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
t0ny_pars0ns
  • 5453 Answers
SOURCE: miele cva 4075
Please advice as to the make and model of this camera. Thank you.
Posted on Jul 22, 2017
Miele cva 4075
Jul 22, 2017 | Cameras
I have a Miele CVA 4075. It has sat in a model home that was never sold with only 36 cups on the counter. But now I just tried using the cappuccinatore and it only shoots steam for a second. I took it...
I'M NOT FAMILAR WITH CAPPUCCINO MACHINES, HOWEVER, THERE MAY BE A SMALL CRACK IN THE HOUSEING SOME PLACE OR SOME THING IS JUST NOT SEALED COMPLETELY WHEN YOU PUT IT BACK TOGETHER. I WOULD RE CLEAN USING VINEGAR OR RUBBING ALCOHOL TO PREVENT ANY OILY SUBSTACE THAT WOULD PRVENT IT FROM SEALING UP TIGHT. HOPE THAT HELPS.
Jan 21, 2015 | Miele Coffee Makers & Espresso Machines
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Sep 07, 2014 | Miele CVA4070 Coffee Maker
Apr 13, 2010 | Miele CVA4070 Coffee Maker
How do i clean my miele coffee system cva 4070?
I have a cva4075 so this may not be exactly the same, but on the 4075 you open the front of the machine and pull out the left hand plastic container on the top. Underneath on the right hand side you will see a small flap. On the bottom side of the flap is a red triangle sign. That flap is the top of the funnel for the ground coffee. You drop the cleaning tablet into this funnel.
Apr 12, 2009 | Miele Coffee Makers & Espresso Machines
Miele CVA- 4075
You need a new Elektronik. The one in the back of the Coffee maschine has to be changed. There is a technical Problem in the Clock Module.
Greeteings ....
Mr. Cool
Dec 02, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Coffee Makers & Espresso Machines Logo
176 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Colin Stickland
Colin Stickland
Jerry Greenberg
Jerry Greenberg
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
