Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Found the unit circulator fan running but not cool in the freezer or fresh food compartment. I unplugged and replugged and the compressor started running shortly. I checked the frost-free feature already (clicked the light switch in the fresh food compartment 5 times in 6 seconds). I took the cover off the back of the cabinet and the compressor is now hot, but not too hot to touch. The unit is just not cooling off very quickly. I know the compressor is only 1.1 to 1.6 amps and that's not much. Is there any way to tell from feeling the compressor, copper lines going into/out of it and the coils next to the compressor if it is working normally now? Or do I just have to wait a few hours and see? If the compressor is running, can it be "bad?" There is no sign of damage to any of the lines, but I suppose the refrigerant could have leaked out some way.
  • 106 Answers
The compressor CAN run and still be defective. It's like having a car engine with a bad cylinder-it loses compression and therefore loses power. Unfortunately, this is indicitive of Frigidaire refrigerators. If the compressor will try and start, maybe for a few seconds, and then shut off, you may have a defective start relay.
Posted on Jul 31, 2009
What do I do,my Samsung freezer is working but not the refrigerator which is not cooling,how much should the setting be on both
The normal setting for freezer and fresh food side is 5. A very common cause of loss of cooling in the fresh food side is the vent are blocked for cool air exchange from the freezer. Find the two vents to and from the freezer to fresh food side and make sure they are not blocked. Most problems can be solved by decluttering freezer and fresh food side.
Next check to see if the evaporator fan is running. This fan provides the push for air circulation through the vent dampers in this type of refrigerator.
If this does not fix the problem and is still under warranty, call the 800 number and pay the small service fee and get a professional to analyze and determine which part is not working.
Hope this helps.
Dec 15, 2014 | Samsung RS265TDRS Side by Side...
The refrigerator is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Amana Refrigerators
I have just purchased the above unit and has been plugged in now for 24hrs with no food, the high humidity warning sign Is illuminated constantly Is this correct?? Also I have yet to witness the operation...
You didn't include a manufacturer or model, so I can only offer general help with your problem. If you choose to provide this info later, you may get better, more specific help. The freezer compartment contains the cooling coil for the freezer and fresh food compartments. This fan in many fridges are not visible - but yours may be. Yours may also have circulation fans specifically for moving air around the fresh food compartment.
Generally, the coil is located in a protected area of the freezer (behind the back panel). The fan is arranged to pull air from the freezer floor through the coil to be cooled and blown out the top of the freezer compartment. Openings between the freezer and fresh food compartment allows a portion of the cold air to be blown into the fresh food compartment.
The first thing to do is to see what the temperatures are in both compartments. The fresh food should be about 36 degrees and freezer -10 to 0 degrees Fahrenheit. Place a glass thermometer (capable of displaying 32 degrees and up) in a glass filled with cold tap water, and place in the fresh food compartment. Place another thermometer in the freezer (capable of reading -10 and up). You can also use thermometers designed for fridge / freezer temperatures if you wish.
If there is nothing in the fridge and the door remains shut, the temperature should be seen in an hour or so. If the temperature range is obtainable, it is not likely that there is a humid condition INSIDE the fridge. You may have moisture collecting on the OUTSIDE of the fridge near doors, etc. If so, locate a humidity switch and turn it on. Many manufacturers provide this switch to turn on electric heaters in the outer part of the fridge cabinet where moisture tends to form in humid climates. These heaters operate to evaporate the moisture on the cabinet and usually come on when the freezer defrost circuit is on.
I hope this helps and good luck!
May 16, 2011 | Refrigerators
Hi, Our refrigerator has stopped cooling and I desperately need to try to fix it myself. Lights still come on. Fan or something is still running but the freezer still works so I thought maybe that's what...
There is likely a problem with the defrost circuit or cold air circulating fan (but could be a low freon charge or other problem). The freezer compartment has the cooling coil with defrost heater and a fan that pulls cold air from the freezer and blows it into the fresh food compartment; based on the setting of the thermostat in the fresh food compartment.
When the defrost heater fails, the area that the cooling coil is located in eventually turns into a solid block of frost and ice. It becomes impossible for air to be drawn across the cold coil, cooled and blown into the fresh food compartment. The result is a rising temperature in the fresh food compartment - and eventually in the freezer section, too. Since the fresh food compartment contains the thermostat and the temperature never gets low enough to satisfy it - the compressor runs non-stop. That is, until the defrost timer kicks in to shut it off for 20 minutes or so.
The first thing to do is to manually defrost the freezer by accessing the cooling coil after emptying the contents of the freezer. This can be a pain in the neck to remove racks, shelves, ice maker, etc. to get to the back wall of the freezer, behind which the cooling coil is found. If you expose the cooling coil and it is encased in frost and ice it is a problem with the defrost circuit. If it is not - the fan is suspect. If the fan spins, check for a blocked path between the fan and the fresh food compartment. Defrost by placing a heat source in the freezer or directing the output of a blow dryer at the coil. If you're unable to access the cooling coil, you can simply empty the freezer and defrost it with a heat source. it will take longer to melt all the frost and ice, but it will work.
If it is a defrost circuit problem, you'll need to check voltages and continuity on the defrost terminator & timer and defrost heating element, fans, etc. after completely thawing the ice & frost.
This job isn't a good first time DIY job due to the danger of freezing skin, etc. due to possible exposure to freon in the system and the tight spaces you'll be working in with live voltages. You might want to call a pro after you've defrosted or put up another fixya request if you decide to dig in on your own and need specific help with procedures, locating parts, wiring diagrams, etc.
I hope this was a good starting point to help you decide whether to go forward or not on your own. Good luck!
Oct 07, 2010 | Kenmore Refrigerators
Refrigerator warm freezer too cold
If you have already adjusted the controls for temperatures in both compartments and allowed 12 - 24 hours to stabilize and the trend is continuing, there may be a problem with the fans that move the cold air from the freezer to the fresh food compartment. The fridge may also start allowing temperatures to rise in the freezer soon, too.
All of these problems originate in the freezer compartment, where the cooling is done. Behind the back wall; inside the freezer - lies the cooling coils, defrost heater, circulating fan(s) and defrost terminator sensor. Unplug the fridge. Empty the contents of the freezer, remove the ice maker assembly and the back wall plate and you should see these components. If it looks like a large block of snow and ice, the problem is with the defrost circuit components. If clear with a minimal amount of frost, the warm fridge is the result of blocked or limited airflow from this area to the fresh food compartment - likely a failed circulating fan. Plug the fridge back in and check to see if the fan is running - since the fridge is warm, it should be running. The fan or the thermostat will probably need replacing if it is not.
If icing or frost is the problem, you'll need to isolate and replace one or more of the following: defrost heater, defrost terminator or defrost timer. The last two are the usual suspects for this type of failure - but the heating element can fail too. Many times, the defrost timer is accessible from the front of the fridge, behind the kick plate below the freezer door on the right side. Other times it is located in or near the temperature control area.
Jun 18, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer door started dripping water when opened and item in freezer are defrosting. Also refrigerator not staying cool. Help
Hi and welcome to FixYa. I am Kelly.
In the fresh food compartment center overhead within about 6 inches of the front of the unit there is a circular hole. Inside that hole you will see a dial with 2 tabs on it. Use your thumb or a squared off utensil and rotate the tabbed dial slowly until you hear an audible "CLICK" The refrigerator should stop running and the defrost cycle begins.
After 45 minutes (+ or - 10 mins) the compressor should start again. Once the compressor starts, check both the evaporator fan in the freezer compartment and the condenser fan in the bottom rear of the unit to make sure they are turning at full speed.
If the compressor does NOT after 90 minutes re-start, rotate the defrost timer tabs of the dial in the overhead of the fresh food compartment until you hear it start again. The fact that the compressor did not start in under 90 minutes indicates a defrost circuit problem.
A slow running evaporator fan or condenser fan will cause poor cooling. Also in the back of the unit, check the right side of the condenser coils for lint / hair build up. If it is blocked the front outside chassis of the freezer section will be very warm almost hot to the touch. Clean as needed with a vacuum if you do find any lint buildup.
Once more thing is to check the ice maker. Quickly touch the bottom of the ice maker. If it is VERY hot to the touch then there is a problem with the ice maker itself and the mold heater can cause your freezer to warm up and overall unit performance to degrade.
A complete checkout of the ice maker can be found here: http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48360
Scrolling the left side of the page will access all sections of the unit.
Thanks for using FixYa.
Kelly
It sounds as if you have an automatic defrost problem.
Jun 13, 2010 | Maytag MTB2156GES Top Freezer Refrigerator
Refigerartor fresh food compartment will not get cold. no air flow through vent. how do i know if it is the damper, temp sensor or temp control switch
you probably have a bad circulation fan in the freezer compartment. its circulates the air from the freezer to the refrigerator compartment which cools the refrigerator portion of the unit. if you don't hear it running , the fan blades are either stuck on ice or the motor is burned out and you'll have to replace it .
Mar 12, 2010 | GE GSS22JF Side by Side Refrigerator
The freezer section of my fridge freezer side by side has broken down and will not freeze. The fridge side seems fine. Is it worth getting repaired? Prior to this I often heard like a clicking/ tapping...
So your refrigerator section is cooling fine ? When the compressor motor is running and you open your freezer, is the fan running ? You might need a simple fan replacement - The most costly repairs to a refrigerator is usually the compressor - as long as your compressor is running and you have cooling, the other most common problems are control board faults, evap fans, defrost timers, all of which can be fixed.
Is your freezer iced up when this happened - turning the refrigerator off and unplugging it, try removing the back panel of your freezer and locate the fan - look for anything obstructing the blades - maybe ice or other......otherwise you may need this serviced.
Is it worth it ? It depends - how much did you nitially pay for this ? How long have you had it ? How much are estimated costs for the repair - if the problem is one thing needing replaced and doesn't cost you a lot of money, yes it is worth it.
Aug 17, 2009 | Whirlpool GS6NBEXR Side by Side...
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Jul 28, 2009 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
140 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
