Question about Casio FX-115ES Scientific Calculator
Can I use the Casio fx-115ES (fx-991ES) to solve a linear dependant system of equations .... (Using the Gauss Jordan method) ???
  • 4,472 Answers
Http://casionz.co.nz/Site/Pronto/Files/user_manuals/FX-115ES%20991ES.PDF
There is the PDF manual if you need it. Yes this is a scientific calculator you should have no problem doing equations using that method.
This is how its done on a ti-83, if that helps you at all as well.
http://www.wvup.edu/cbrady/GaussJordan.pdf
Please let me know if you have any other questions.
Thank you,
Lee
Posted on Jul 30, 2009
I want to solve an complex equation on casio fx-570 ES Plus
Your scientific calculator is unable to solve complex equation with complex coefficients. You should try to solve by hand directly using the quadratic formula or by factoring the polynomial in z
failing that, another way would be to set z=x+iy, substitute this for z, carry out the algebra and try to separate real and imaginary parts. But your two equations will constitute a system of two quadratic equations. I am not aware of any general method to solve coupled nonlinear equations.
Good luck.
Dec 20, 2012 | Casio FX-115ES Scientific Calculator
How do I solve for y, 2y + (y-3)=18 - 2 (y+3). with the casio fx-300es? and if I cant whats the calculator that will. thanx
Do you really need a calculator to solve a linear equation?
Let us see how to solve it without a calculator.
Remove the parentheses fronm the second term on the left : y-3
Use the distributive property on the last term on the right side -2y-6
Take the term -3 to the right side, changing its sign in the process (becomes +3)
Take the -2y term to the left making it +2y.
3y +2y=18+3-6 or 5y=15 and the answer is straightforward .
As to your Casio FX300ES, it cannot solve equations because it does not have an EQUATION calculation mode. The Casios FX-115ES and FX-991ES have an Equation Mode. If you use any of the two to solve an equation in one variable (linear, quadratic or other) the unknown is taken to be x by default. You would have to change the name of the variable from y to x.
Sep 08, 2011 | Casio fx-300ES Calculator
Solving linear equations in 3 variables by matrix method in casio fx-115ES
Press key Mode, first select option 5:EQN (by pressing key 5), then option 2: a_nX+b_nY+c_nZ=d_n (by pressin 2).
Now input coefficients from equations in table (each column is for one variable), just type in number and press =, then use arrows to move to another cell.
Sep 02, 2011 | Casio FX-115ES Scientific Calculator
I knowi can find a linear equation if i have: two points {for example A(0,0) and B(1,1) the equation is y=x} or one point {for example C(0,2)} and a slope {for example m=2) the equaton is y=2x+2 can my...
The general answer is no. However the calculator can be used to find the slope and the y-intercept. You write the formula for the rate of change (a) and use the calculator to calculate it. Then you use the formula to find the y-intercept.
If you have 2 points, you can use the 2 -var statistics program to find a linear regression.
Jul 05, 2011 | Casio FX-115ES Scientific Calculator
How can I solve linear and non-linear equations
Set Computational mode to EQN by pressing [MODE][5:EQN]
Select the type of equations you want to solve
Select the relevant otion and get ready to type in the coefficients (the a's, the b's, the c's etc`.)
For more general non-linear equations, use the SOLVE feature.
Feb 11, 2011 | Casio FX-115ES Scientific Calculator
How to do x=BA^-1, in order to solve a system of equations 3x3 with a Casio FX-115 ES
Let your system of linear equations be [A][X]=[B] where [A] is a 3x3 matrix, [X] is column vector ( a 3x1 matrix) , and [B] is also a column vector or (3x1) matrix.
Assuming you are able to invert the [A] matrix to find [A^-1].
Multiplying on the keft by [A^-1] the system of equations you get
[A^-1].[A][X]=[A^-1][B].
But since the product [A^-1][A] is the (3x3) Identity matrix, the left side of the equation is jut [X], while the right side is [A^-1][B]. As you can see it is not [B][A^-1] .
To solve your problem, you should define your [A] matrix, define the [B] column vector (3x1) matrix, then perform the operation [A^-1][B] using the [X to -1] power key to calculate the inverse [A^-1].
Jan 10, 2011 | Casio FX-115ES Scientific Calculator
How do i solve a matrix?
What do you mean by "solve a matrix"? Find the inverse? Find the determinant? Find the solution to a system of linear equations? Within limits the fx-115ES can do any of these and more.
The procedures are described in the "Matrix Calculations" section of the manual. If you still have problems, please reply to this post specifying what you want to do.
Nov 18, 2010 | Casio FX-115ES Scientific Calculator
How do i calculate limits on my Casio fx-115es? Ex. lim x->3 for (x2'-0)/x-3
Sorry, but you cannot calculate limits of functions with this calculator. It does not have a Computer `Algebra System (CAS). For that you need a graphing calculator with CAS: Casio ClassPad 300, 300PLUS, 330, HP 48 GII, HP49 G/ G+, HP 50G, TI-NSPIRE CAS, TI89 Titanium, TI 92/92PLUS, TI Voyage 200 PLT. It is still a very good scientific (non graphing) calculator
However, you can calculate numerical derivatives, and numerical integrals, solve linear and non-linear equations.
Even though this post does meet your expectations, do not let that prevent you from rating it.
Jan 21, 2010 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
268 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
