Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My dishwasher is going crazy -- keeps turning both drawers on, beeping like crazy, and sounds like it's trying to wash, even when the drawers are open! HELP! Laura
  • lmpope Jul 31, 2009
    Not sure yet--haven't had the repairman out yet to see if it really was the control board.
  • 3,037 Answers
Bad Control Board is most likely the problem, as nothing else really would cause this and as long as you are getting water into the machine still. You should be able to order a new one though the place you bought it or through the manufacturer themselves. Let me know how this turns out.
Benjamin
Posted on Jul 30, 2009
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
It is the middle of the night here and the dishwasher came on and is beeping on F! message. I cannot turn it off. Please help.
cohassetmusi
  • Rank: Master
  • Rating: 100%, 1 Votes
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Aug 05, 2011 | Fisher and Paykel Dishwashers
Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Jun 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Can the beeping alarm be turned off?
usually if you turn the power off and on after a short delay the beep should go away. But the alarm fault code will keep showing on the display / drawer panel light until fault is fixed.
Hope this helps.
Feb 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher and Paykel dishwasher will not keep running.
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the door is open or closed. Wipe these areas with a clean dry cloth...Give it a try
May 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher Dilema
You need to remove the bottom drawer and dry out the water with towels and a hair dryer when this is done it should operate normally. most likely when you pulled out the drawer the water sloshed back and out of the drawer making the dishdrawer think it was flodding turning on all drain pumps. If you look at the back of the drawer about two inches from the floor you will see an oval hole off center to the right. That is where the water got out.
Jan 10, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
85 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
