Question about Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch shu5300 dishwasher
The normal wash staet at 76 min instead of 94. Cycle runs to 1 min and stays there. To drain I must cancel program and run rinse cycle. Water does not get hot, I don't think. If its the control board then where is it or if its the heating element how do I test it and where is it.
Your help would be appreciated.
Bill
I had the 'Reg Wash' button fall off and can not get it back on.
How does one get the front of the door off to click button back on?
Thank you
readymix
Posted on Oct 22, 2008
  • 213 Answers
There is a relay on the main control board that has gone bad. you have to replave the whole board to fix the problem
Posted on Nov 24, 2007
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
Dishwasher during normal cycle gets hung up and does not advance
HI. this is just a control fault. you can try to reset the core program by unplugging this unit for 5 minutes. this will drain all power and reset the core on the timer/control.
If you experience the same situation after this reset, simply replace the control/timer module.
Jun 02, 2009 | Kenmore Dishwashers
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 23 in. SHU5302UC Built-in Dishwasher Logo
286 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
