Question about Remington Garden
I have a 6 month old remington 16" electric chainsaw, model # 107624-01. The nylon sprocket gear's teeth have all be worn down. Most likely running it with a too loose a chain. The part # is 078801 and is no longer available! Geeesh. 6 MONTHS OLD ! Any suggestions? Thks. Dan
    President:
  • 704 Answers
Try Master Distributors, they have them in stock for under $10 (plus shipping).
Here's a link to the part you're looking for.
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=107713-01
You can also give them a call and provide them with your model number of your chainsaw. Your sprocket number is #107713-01
Hope this helps you get cutting again! Best regards!
Posted on Jul 31, 2009
Remington Pole Say
check for a roll pin in the gear or shaft that has sheared off
check that the square end of the drive shaft is not rounded off or that the square drive in the gear is in fact locking on the drive shaft and not turning from worn out
Jun 20, 2016 | Remington Electric Pole Saw
Motor runs but chain does not move
Probably the shaft on the sprocket has sheared off.
Knox Knolls Outdoor Power Equipment
Springfield, IL 62704
www.knoxknollsope.com
Oct 14, 2012 | Remington Electric Chain Saw
Motor runs, chain does not turn
It occurs because it is plastic gear on a low cost saw.
I went to Remington and found the IPB for your saw.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-BD.pdf
The gear is pn 107713-01 and NLA at Remington (no longer in production, no local support either).
Input "107713" here and found 2 results
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
If me and I were going to try a repair I would use the 122511-01 for the bearing if nothing else.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 20, 2010 | Remington 16" Electric Chain Saw
Motor turns --sprocket or chain doesn't
I'm assuming your kill switch is not engaged, the front handle should be pulled to the rear. It's normal to have some damage on the sprocket from loose chains catching on the corner so I doubt you need a new one. The motor turns? I'm assuming you're talking about the clutch, and if the clutch spins but the chain does not it sounds like your bar may be damaged or as you said the sprocket may need to be replaced if it's seriously been misused.
Apr 15, 2010 | Remington 16" Electric Chain Saw
I need a sprocket assembly for my EL* 107624-02
Afternoon Happy;
The obsolete chainsaw Gods smiled on you today, but there is a catch 22. You must purchase a repair kit to get the parts you need.
Master Distributors
Part number 122511-01; SPECIALTY PARTS: SPROCKET GEAR (107713-01 SPROCKET GEAR, 075676 BEARING, 059606 DRIVE GEAR) (DSSP-SH); $16.99.
Are you aware RemingtonPower has ceased production? Soon eBay will be the only source for replacement parts.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Remington 16" Electric Chain Saw
Where do I get a Remington 16" EL8 chainsaw repaired for what seems to be a Gear Train Failure. I need a repair outlet near Beaverton, Oregon, 97007
Remington Service Center Locater
http://www.remingtonpowertools.com/service_locator.cgi
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
I think your model is 107625. A complete "SPROCKET DRIVE GEAR BEARING KIT 747" part number "122511-01" is listed at $16.99
Are you aware Remington is no longer in production and most replacement parts are exhausted? Before driving to any repair facility please contact them. If you undertake the repair your self please call 1 (800) 475-5660 (have saw within arm reach). Inspect your saw and verify my model number matches your saw.
Please do not punish my rating because you are unhappy with RemingtonPower. I provided a very helpful answer, perhaps not the one you wanted to hear. Sorry
Lou
Nov 30, 2009 | Remington 16" Electric Chain Saw
Need sprocket (part #75752) for Remington 16", 3.25 hp electric chainsaw, model #100089-05, also numbers 71 34281 on box.
This should be part # 107713-01 - internal gear. Most likely used with a panhead shoulder screw part # 076905. Source: PartsFor.com
Oct 07, 2009 | Remington Electric Chain Saw
Missing nut and sleeve for sprocket cover for model 111174
Duplicate question... duplicate answer.
You provided no model number. It is probably here:
Remington.com
http://www.desaparts.com/remington-chainsaw.html
If not there is a home button at the bottom of the page that provides a 1-800-number. GL
Lou
Oct 06, 2009 | Remington 16" Electric Chain Saw
Remington.com
Lou
Garden Logo
224 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
