Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Same kind of deal...it just stopped!
I was vaccuming out my car and it just stopped!! Plugged it in different plugs and no dice. Weird. So, waiting a couple hours and pluggin it in should fix it?
  • 40 Answers
Either you bent your power cord to much and there a break inside of it or one of the connections on the motor came loose.
Posted on Aug 01, 2009
Just stopped working
Motor Failure. This tends to happen when filters are clogged both cloth bag & Round Cartridge these vaccums draw in atmosphere dust into the hood of unit to which is meant to cool motor but also causes problems.
Apr 12, 2014 | Fein Turbo II Dust Extractor 9-20-25
My rotating brushes have stopped rotating
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
May 07, 2012 | VAX Appliances Vacuums
Vacuum cleaner does not work
most upright vaccums have a reset button at lower rear area of the vaccum. operates similar to gfi plug reset, push button back in usually with small screwdriver. is your debris bag to full? power brush jammed with debris? hose plugged? this will cause motor to over heat and in turn kick out reset button. always unplug power cord before putting fingers in areas where moving parts are!!
Jan 01, 2012 | Bissell Vacuums
The vaccum just stopped working while in use
It's either plugged or clogged in the filter, which triggered the internal thermal shut-off. Clean it out and wait thirty minutes and it should work.
Dec 08, 2011 | Eureka 3041BZ Upright Vacuum
When I plugged in my Dyson flames came out of the wall socket and the vaccum stopped
Sorry to hear about this. Please get in touch with us directly so we can provide assistance - you can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 20, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When you plug in the vaccum it sparks from the outlet
If it trips the breaker, you have a short somewhere from the cord to the motor. If not, be sure to wait until it's plugged in before you turn the switch on. Turn it off before you unplug it.
Dec 30, 2010 | Electrolux Vacuums
Plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Dec 31, 2008 | Hoover Windtunnel Supreme U5280-900...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
110-220V
You may have burnt up the motor field when it was plugged into a 220V power source. But there are drop down transformers you can get to reduce the voltage form 210 to 110. AS Radio Shack or similar store would have them.
Jan 05, 2008 | Kirby G4 Bagged Upright Vacuum
G5 does not suck:)
un-plugthe vacum andget a broom stick and slide it throuh the hose! it's clogged!and change the bag!
Jul 29, 2007 | Kirby G5 Bagged Upright Vacuum
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
69 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
