SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
SOURCE: VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
SOURCE: can't dubbing because it is stuck on DV/D8 Dubbing, need change
I had this problem too. I had to go to the -R.
SOURCE: Dubbing from DVD to HDD
You did get this from me but, if you are trying to dub a protected dvd, the dub option will be greyed out. Non-elegant solution: use another device to play the dvd and run it as input into the DVDR. You won't have the menu items but you will have the video.
