Question about GE Refrigerators
When we open the freezer door, a lot of steam/smoke comes out. A lesser amount comes out when the fridge door is opened.
    President:
  • 704 Answers
If the fridge is working and keeping things cold and frozen, you don't have a refridgerant leak that is producing vapor that might appear as steam or smoke.
The steam/smoke is actually water vapor being made visable due to the temperature difference between the freezer/fridge temperatures and the air temp in the room (or garage) the appliance is in.
It's nothing to worry about and is normally more likely to happen when the outside or house air temp is very warm (Summer months) and when the air is humid.
What's happening is the very cold and cool air is hitting and mixing with the much warmer and much more dense air (humid air contains microscopic water particles) when you open the doors, and is instantly being cooled. Thus it appears as thou the fridge is steaming or smoking.
Have a great day an hope this explains the situation. Best regards.
Posted on Jul 30, 2009
We bought used fridge Inglis/Niagara Model ICT85000 Mfg06/93 when we close fridge door freezer door opens. When we close freeze door fridge door opens. This is a top freezer. Is there a repair
Inglis are a budget make. The cold for the fridge comes from a vent from the freezer. Don't let the door slam. You must close them gently.
Dec 30, 2016 | Refrigerators
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Sep 17, 2013 | Freezers
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
Freezer is cold, but refrigerator is warm. The fan is running, but I don't feel cold air coming into the refrigerator compartment. There did not appear to be a large amount of frost anywhere, but just...
If the freezer is cold the compressor is Ok. Now if its a two door fridge . Open both the doors while the fridge is On. Press the lower door switch ( the lower light should turn off and you should hear the fan humming sound come on ). While holding the door switch pressed close the freezer door, you should see cold air come out of the slits in the back of the lower compartment. If not icicles have blocked the passages due to the non working of the heating coil.The heating cycle is controlled by the timer switch located near the compressor at the back. Unplug the fridge and remove the timer switch.Note the color of the wires and mark on the old switch. Replace and it will work.Only frost free fridges have heating cycle
Mar 07, 2011 | Refrigerators
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Feb 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Refrigerators Logo
599 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
