Low water level kenmore elite front loader i have cleaned the hose strainer,water pressure 55 psi can i adjust
    Scholar:
  • 84 Answers
Whats tthe model number on the washer? I wana check if that model has a "water flow meter". Does the washer fill then give you an error code about the water pressure? Is this the HEt front load washer? If so, open the top panel. 2 screws are located on the back upper corners. one on each side. slide the panel back and lift up. Now you will see the inside from the top view. Now if it does have a "water forw meter" it should be inline with the water inlet caomming in. Its looks like a plastic like tube that is in the middel in the inlet water coming in..i would check that out.
Posted on Jul 31, 2009
How much water pressure do you need to operate a front loader kenmore elite. We have 28 psi from water well.
Check the following items:
1. The inlet screen at the hose water inlets to be sure they aren't clogged. With well water, debris can sometimes be an issue.
2. The water valve(s) are open
3. The water line(s) are not kinked
4. The water line(s) are not frozen
5. To be sure there is an available water supply, disconnect the water lines (hot and cold) and try running them into a drain while they are not connected to the washer.
Feb 08, 2015 | Kenmore Elite 45986 Front Load Washer
Fills with water till it overflows especially in rinse cycle no matter what water level setting
most probably cause is water level/pressure switch or h hose.  either needs to be replaced or hose needs cleaning or came disconnected..
Jul 20, 2010 | Kenmore Elite 45986 Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis Elite Type 580 flashing LF
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Got a F35 error at the Kenmore Elite 45986 Front Load Washer. Tried several things including, running with only clean water, used only HE detergent, but still got the error.
Jan 26, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite top loader washer has LF error message
Oct 19, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer has LF error message
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
