Neighbor lady (late 80's) has constant problems. Usually I can press sat button and tv will come bck on. tv screen says video and I can not get it back to tv. Help??
  • 616 Answers
Simply change the channel on the tv to ch. 3 or 4 use the front panel, otherwise use the remote to select source , input.
Posted on Jul 30, 2009
Video display problems
Try disconnecting the power for a minute or two. Usually it doesn't take long to swich between functions.
To get the Seup menu on the screen, you first need to press the Receiver button before pressing Setup. Did you do that?
May 12, 2010 | Onkyo TX-SR605 Receiver
Hi, I recieved this tv from a neighbor some time ago, but I don't have the remote. I use the satelite remote to view the tv. This morning, I turned it on as usual, but when ever I do I have to set the...
Hello check the cable box connections to see what type of connection you are using for television, if you are watching in HD then you might of changed the video input or source button was hit by mistake.
Dec 20, 2009 | Televison & Video
When i turn on the tv it goes to a Dish Screen when i push select it doesnt do anything
I most likely need additional information to ensure this is in fact the correct resolution to your remote issue- but it sounds as though the remote may be in tv mode. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, which will enable you to be able to press select to proceed past the DISH Network screen. The "SAT" button is labeled & in the upper left hand corner of the remote just press SAT once and then release, the button should briefly light up red & then will go off, you can then press select and as long as the SAT button lights up when you press select or any other button on the remote then your all set to go! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Sep 29, 2009 | DISH Network ViP622 DVR DTV Receiver /...
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
I would like to know how to pro. 103602 ir remote
In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
What button is the address button
SAT button it does not work, you can not turn on or off the DISH
First press the SAT button at the top left hand side of the remote and release. Now try changing channels. If this did not work press the menu button twice on the receiver. It will usually be behind a pop open door on the right of the receiver. I f your receiver does not have these buttons you can access the system info screen by pressing the power button on the receiver while holding down the arrow left or right key.
Once you have come to the SYSTEM INFO SCREEN press and hold the SAT button on the top left side of the remote until all lights across the top light up. Then key in a two digit number e.g. 01-16 and press the #key. then press the record button and the remote address for the location you are trying to control should change to the number you keyed in. If this is the second location tv that was giving you issues exit out of all the screens on the receiver location tv and go to the other location and try the remote. If it is the tv where the receiver is located then you should now be able to use the remote to maneuver the yellow cursor across the screen. If you need further assistance please let me know. Thanks for using Fix Ya.
Dec 11, 2008 | DISH Network IR Remote Control
"video" letters/number on screen
You need original Sony TV remote to disappear on-screen display by pressing Display button on that remote.
Tip: You can try any Sony TV remote to fix this problem. Borrow a remote from friends, neighbors like that.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
