Question about Roper RS25AEXLQ Side by Side Refrigerator
The divder between my frig and freezer is also hot
Is this something I can repair or do I need a new frig? it's a Roper model RS25AGXNQ00
  • lpenn94 Jul 31, 2009
    Thank you so much for the help. it doesn't have an energy switch. thanks again you took some worry off me.
    President:
  • 704 Answers
This is normal. Modern frost free fridges have heaters built into the front edge of the cabinet to help keep the accumulation of surface condensation and excessive ice build up on the door edges inside the freezer and fridge.
It is nothing to worry about, but you might have an energy saver switch inside the fridge section that you can turn "on" to turn OFF the heaters (energy saver means the power using heaters would be OFF when the energy saver is "on", turning it "off" means the heaters are ON.
But not all fridges have a switch to turn off the heaters, so don't worry, just accept it and don't buy a new fridge until you need to.
Hope that helps, best regards!
Posted on Jul 31, 2009
  • Roper Master
  • 3,361 Answers
It is normal operation to reduce condensation. Leave it alone.
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
MY ROPER FRIG.ISNT COOLING ON FRIG.SIDE .FREEZER WORKS GOOD
Check fans worrking ok, condenser clear and clean, vents fully open, freezer not iced up solid blocking airflow.
May 19, 2012 | Roper RS25AEXLQ Side by Side Refrigerator
Roper top freezer clicking and not cooling
I would start by changing the relay on the compressor, thats more than likely where the clicking noise is coming from. Whirlpool brands are notorious for that part going bad, especially ion the early years.
Apr 24, 2012 | Roper RT21SKXLQ Top Freezer Refrigerator
RS25AGXNQ00 roper icemaker leaking. Bad solenoid?
if what you see is water/ice build up overflowing from the i/m yes indeed the water valve isn't fully closing and needs to be replaced
Jul 20, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Roper # RS25AGXNQ00 the freezer side too cold around -22+ and the fridge side 51+ also found ice forming inside the air diffuser. Any suggestions?. Thanks
Make sure the settings are on the recommended setting, If so check to see if the freezer bottom is frozen over with sheet ice, if it is than you either have a leek in the ice maker or a clogged defrost drain line. The excess ice obstructs the air flow from the freezer to the refrigerator making the freezer to cold and the refrigerator not.
May 20, 2011 | Whirlpool Refrigerators
Not cooling good
There is a fan down by the compressor that aids in cooling compressor and getting rid of the water that comes out of the freezer during defrost cycle. I am sure that you took the paper cover off the back of the unit on the lower back side so your unit might not have a fan. Now lets look at the fan inside the freezer is it running can you hear it when you open the door? Does the compressor make a clicking sound as it is hot to touch and trying to come on? get back with me ok ken
Jan 31, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My roper frig it has water inside under the vegie
clogged freezer drain in freezer. remove cover and work some hot water in and out of the drain with a turkey baster until water runs thru and then poutr more water thru drain until all ice is washed thru. good luck.
Jan 20, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Mod#RS25AGXN002 FRIG NOT COOLING FREEZER NOT FREEZING
the return air ducts are iced up and need defrosting, empty the fridge and freezer and unplug for 3to 4 hours with the doors open
Oct 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Roper model # RT18DKXFW01 not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgjfd
Aug 14, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper RS25AEXLQ Side by Side Refrigerator Logo
319 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
