Printers
Problem for Printers
Generic problem for all Printers
Printer problems
By sharron on Nov 24, 2007
my printer wont print can you help me with this problem.
Same Problem
Nov 22, 2008
-   cartridges won't return after i installed them. I can't take them out since it is jammed inside. -   Guest
May 14, 2008
-   paper will jam,give some solution.-   Guest
Apr 11, 2008
-   The cartridges won't allign and it jams sometimes when trying to allign or does not print any allign ment, the paper comes out blank and then the red exclamation sign cimes on and the printer repeats the message press enter to allign cartridges. this goes on and on.-   paurio
Apr 07, 2008
-   The printer says that the cartridge needs replacing but the cartridge is new. Tested it by trying to copy a page and it comes out blank.
Have tried a new large black only cartridge and also a colour and black combined cartridge and the same message shows. Have also tried cleaning head and nozzle and roller and that does not help either-   julietr
Mar 30, 2008
-   my printer won't print, the paper feeds ok , but it won't print or copy? any suggestions . thank you.-   halaby
Solution #1
posted on Apr 26, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
download software for LexmarkX1270
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
Can anyone explain me how can a refill cartridge can damage my printer ..since it is the lust piece... (More)
Answer
My MultiPass F60 Alarm light is blinking. It says "Check Printer/Press Resume". I have... (More)
Answer
how to stop printer template information printing out
32 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 06, 2008
Every thing is in and hooked up tight, but the printer still won't print. Can you help me.
Comment by Guest, posted on Mar 03, 2008
Printer wont print 4 X 6 photo paper the paper gets stuck half way through
Comment by Guest, posted on Mar 02, 2008
we cannot print a photo from the computer, we have taken all steps they've recommended, still nothing. printer is only 2 months old. I'm getting very frustrated, they keep telling me to check print queue, but don't know how to do this thnx audrey.
Comment by linda1953, posted on Feb 17, 2008
At first it would not feed paper at all altho it went through all the motions. I clean the roller per recommendations and then it just slide the paper through and I get the message to shut down for 10 seconds.
Comment by coolie_66, posted on Feb 16, 2008
hp psc 2355 All in one printer,
When directed to print from computer to printer will not even recognize command, can make copies tho. It started with paper jam.....then printer alingment problem , replaced carterages ....fixed that issue shut off for a while now nothing but copies.
my email coolie_66@yahoo.com
Comment by griden, posted on Feb 11, 2008
paper feeds through but does not print
Comment by emot, posted on Feb 01, 2008
Printer will not print. When you look at the progress it goes to 14% printing and then nothing. Will copy but not print.
Comment by printya, posted on Jan 23, 2008
everything installed but printer won't print says printer not installed even though it's marked ready. Re-installed software, checked to see if it's compatible and it is, am out of ideas here, need to print.
Comment by Guest, posted on Jan 22, 2008
I clean the heads, have put in new toners and done the diagnostics - but when I try to print out any document the ink just appears to fad and by the second page it comes out blank.
Comment by gildedpeach, posted on Jan 17, 2008
A page feeds through but nothing prints. please help!
Comment by saliangel87, posted on Jan 08, 2008
everything is connected and has ink but the paper won't even go through
Comment by fbbmartinez, posted on Jan 08, 2008
I"m using a p3005 printer on a sco/unix network, with dos. when I print to the printer, a page feeds, but nothing prints on the page. I know it prints because if I do a test print from the pritner itself, I see data on the page. (get diagnostic data of the print server)
We're working on installing the windows drivers to get it to work, but still testing. please mail me @ frank@actual-america.com
Thank you in advance for your help,
Frank
Comment by Guest, posted on Jan 03, 2008
will only print partial heading and then nothing,the rest is blank
MY NEW LEXMARK Z735 WON'T PRINT, DESPITE DOING ALL DOWNLOADING AND CONNECTION.
PLEASE HELP
Comment by TraceyLe, posted on Jan 01, 2008
It connects, it feeds, it goes through the motions of printing... but the page comes out blank. I have tried in both copy and print mode.
Comment by MCHS, posted on Dec 31, 2007
P310 printer won't print after installing new print cartridge. Print drop keeps flashing like there's no ink. I took print ribbon out before installing, tried reseating cartridge several times, turned printer off and on several times. Printer sends paper through and acts like it's printing, but no ink comes out. I shook cartridge gently and pressed cartridge onto paper and there seems to be ink in the cartridge. The ink cartridge is the same kind as the one I got with the printer so I know it's the correct cartridge.  Is it possible to get a bad cartridge that I should return to the store for a replacement?  Thanks for your help.
Comment by jeaner, posted on Dec 29, 2007
not prinitng.
i just replaced the empty black cartridge, and now it won't print. icon on task bar is flashing. i have shut down the printer, restarted. and also the computer. no result..
Comment by jillhorn, posted on Dec 26, 2007
seems to be working but when paper comes out there is no pinting on it..
Comment by Aspenni, posted on Dec 13, 2007
Exact problem that printer is ready but prints out blank pages. Have run all diagnosis several times with no results. Please tell me I don't have to trash this All-in-One Printer...!
Comment by Guest, posted on Dec 12, 2007
won't print. Yellow triangle blinking
Comment by Guest, posted on Dec 09, 2007
the red and green lights are flashing...the reset button is stuck.... won't release, won't print
Comment by Guest, posted on Dec 06, 2007
Comment by ohio4455, posted on Dec 04, 2007
The printer always works untill my son tries to print then It is all screwed up.
He has several different jobs in the queue which I then delete before I print then the printer will hold that job in it's queue. My next step is always to delete the printer then I have to reinstall. What can I do differently to fix the problem instead of reinstalling
Comment by rlnida, posted on Nov 27, 2007
Printer does not print. Did a head cleaning 4 times, did a head aligning but the printer does not print anything eithre using the control panel or from within Windows. Any suggestions?
Comment by MJFG, posted on Nov 26, 2007
everything seems to be working but when the paper passes through the printer it is blank. have just replaced the cartridge & it only printed once. Have gone through the troubleshooting process, no luck.
Comment by Guest, posted on Nov 24, 2007
printer not printing but it says its ready.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
