Toshiba 27A33 27" TV
Problem for Toshiba 27A33 27" TV
Upon powering on my Toshiba 36" I get the normal.......
By tinae47 on Jul 30, 2009
crackling sounds and nothing happens, no picture no sound but if the set sits for 24-48 hours and I try again, the tv will work perfectly when I turn it on. I have since sent the tv to the repair shop and by the time they get to it, it works and they can't seem to find anything wrong with it. The first time I sent the set in about 2 weeks ago they repaired it and charged me around $200.00 and sent it back to me and the next day I tried to power it on and nothing happened. I called them back and they picked it up and after 5 more days of waiting I called them and they said they can't find anything wrong with it. So I got the set back and after turning it off, I checked it and it did not work again. All I get is an attempt to power up but falls short for some reason. I also get the flashing red power light that will flash/blink but thats all I get. But if I wait a couple of days and not touch it, it will work fine when I turn the set on. Very confusing. Please help me.
Solution #1
posted on Jul 31, 2009
Not Rated)
villamore
Rank: Master
Rating: 78%, 11 votes
first of all have a nice day..the problem of your tv is a COLD SOLDER meaning there's only loss solder causing by overheated component such as resistor, tranformer etc. check and look closely to all of the suspected terminals, someting looks burning, try to solder all the susupected terminal using soldering iron and solder. chek also components it maybe cracked resisitor or diodes
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27A33 27" TV
Questions and Unsolved Problems for Toshiba 27A33 27" TV
Do you recommend Toshiba 27A33 27" TV?
Answer
Answer
I bought a Toshiba LCD tv and the code in the book for the remote, for Bell Expressvu does not work.... (More)
Answer
i need the code for a 27" model # cf3de50 serial #18572871
Answer
I can't sync my cable remote witn my TV, used all the numbers listed with the remote, but still... (More)
Answer
I unplugged the tv to move it across the room, now I have no sound. I didn't do anything but unplug... (More)
Answer
I need to change TV VIDEO without using the remote on a toshiba 27a33
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
