Question about Maytag Atlantis MAV6451 Top Load Washer
The small pully broke off, how to I order one
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
It's off to a parts supplyer
they have theise things called diagrams use phone to take a picture of gear assembly and go to the appliance repair guys shop
and i dont mean bobs repair
i mean call maytag and ask where to buy parts localy and go there they have the book you need to see to get the pulley you need
Posted on Jul 30, 2009
Got the dryer tore apart the belt was broke and pully was laying in flour ..question is where exatly does small pully go back in at?
If you look at where the motor is, directly in front of it on the floor there are two slots. This is where the the pulley slides in and rest. Here is a video that I think will help. http://youtu.be/JXf2AL1MEzA
May 11, 2012 | Kenmore 63942 Dryer
Belt broke and drum will not turn
replace belt order belt using modle number,,,check tension pullys also for damage,,,,,,,,,www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
How do you change a tension system on a 1999 chrysler town and country the engine is a 3.8
if your set to do it. First you have to dismantle the front of the motor. then unload the tension pully. unbolt the water pully the steering pump. then the tensioner. replace here's where it get hard in the small space you'll have to put tension on the ten to put belt back on. broke hand here.
Dec 06, 2009 | Chrysler Town and Country Cars & Trucks
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you adjust tension for drive belt
first you need to figure out if you have an automatic tensioner or an adjustable one. so look at the pullies which ones are not accesories (ie not an alternator pully, power steering.) some pullies will just be on there own not driving anything. is this pully connected to something like this O>o <--this end is the pully.
pully mounting bolt ^ ^arm with hole for rachet
or does it look like the pully is attached to a threaded pole.
the auto adjuster need a rachet to pull back on it (because it's spring loaded) while you install the new belt.
the other need the nut on the pully loosened and the threaded pole loosened will move the pully removing tension from the belt (opposite will tension the new belt).
tighten belt until you can only twist it in half.
Jun 25, 2009 | 2003 Toyota Camry
Broken pully
crankshaft pulley.
Mar 22, 2009 | 2004 Infiniti I35
Pulley broke off motor i need to know what the pulley is called to be able to order it
i need to know what part of the motor the pully came off. a ideler pully is smooth the other pully have grove
Mar 22, 2009 | Infiniti I35 Cars & Trucks
Crank Pully
You may need to get a special crank pulley tool for Honda/Acura. Or you can use an old crank pulley belt and hold it down with a small monkey wrench or something. Then crack the nut counter-clock wise.
Dec 16, 2008 | 1996 Acura TL Series
Broke timing belt
now I read your problem, ok lets start with some critical points once you have removed the plasic or metal belt cover you really should set the upper and lower pullys to the pointing locaters but in a push you need to take a sraight edge and create a line across the pully and on the block use as small a permanent marker as you can a tip as the pullies must be spot on when belt is reinstalled. your tensioner is spring loaded and bolted in place when you remove the belt the pully will mostly go unsprung.
Jun 21, 2008 | 2001 Ford Escape
Maytag Atlantis MAV6451 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
