Question about Garmin StreetPilot C330 GPS Receiver
I don't have any cables for the garmin pilot 330
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Is there an sd port ????
or go to http://www.ebay.com
Posted on Jul 30, 2009
Need instruction manual for operating the street pilot 330. I connected it to the car power sourse but it would not turn on.
Here's the link to the user manual for your Garmin C330.
(Click here)
http://www8.garmin.com/manuals/StreetPilotc330_OwnersManual.pdf
If this information was helpful, please rate my answer with a big thumbs-up. Thanks!
Feb 07, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
My garmin street pilot 330 will not power on
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Lee
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
StreetPilot C330
Go to www.garmin.com and read about "Map Updates" Enter your unit's serial number and see if there's a newer map available. It will explain about how to buy and install the update.
Jul 01, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 330 street pilot keeps shutting down, only had it 1 year
Have you tried charging the unit on the computer? If not, try doing this for a few hours. Sometimes it can help.
Nov 04, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot 2620
Go to Garmin website http://www8.garmin.com/support/blosp.jsp and download the latest USB drivers.
Nov 03, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
