Question about Yamaha YSP-1100 Main / Stereo Speaker
Wiring Why do I need to use component cable connections from the Yamaha to the TV, as the Yamaha is only a sound system.
  • mojom Nov 25, 2007
    yes please
In order to see the OSD (On Screen Display) setup menus provided by the YSP1000, it has to be connected to a display device!
This is very clear in the manual which I gather you haven't read.
Posted on Dec 02, 2007
Your yamaha is not only for audio systems, it can also control video inputs. wether you play dvd/ld/vhs etc... your yamaha will select and you need to connect your TV to the output of your Yamaha needless to select video sources.
Posted on Mar 31, 2008
How do i hookup my magnavox mrd 210 to my lcd tv for surround sound. have tried to connect with rca wires in back of tv to surround sound system and nothing. tried side of tv and nothing. my surround sound...
Have you seen the user guide?
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036122.pdf
The TV is intended to be an end point of the video, not a source of audio. Many TV's (monitors) don't have ANY audio, much less surround sound capability. Composite Video is theminimalist video connection for setup; Component video to the TV should suffice for viewing DVD's.
Is your TV the SOURCE of surround sound programming (via an antenna) or does the programming come from elsewhere like a Cable Box? THAT would be the source you need to tap for surround sound.
Aug 23, 2011 | Philips Magnavox MRD210 System
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Hi .. need to connect my tv audio through my pioneer 5.1 home theater.I was using normal video audio cable ...shall i use component cable???pls advice
"Component" cable refers to the 3-wire hi-def video connection. It's irrelevant to audio.
Assuming you get all your TV programming through a cable box...
The TV wouldn't actually be a source of audio.
I would advise you to route the Cable Box's BEST DIGITAL audio directly to the Pioneer model number ????? (which would be helpful to know for this conversation).
Run the cable box's normal analog audio to the TV so you can watch it without the Pioneer turned on.
And route the best Cable Video (HDMI, Component?) directly to the TV. Unnecessary paths through the receiver can degrade the signal.
Feb 16, 2011 | Pioneer 1000 Watt 5.1 Surround Sound...
How do I hook my PS3 gaming system into my Yamaha Rxv2600 receiver. I can get sound but do not get video. I had to use component video from the receiver to the TV because that was the fire code for...
Use HDMI - I don't understand what you mean by "fire code". HDMI uses less cable involvement, where as component uses five cable to produce video - no audio. HDMI accommodates the audio signal as well. However, if you want 1080i, this will only work for component - you need 1080p for HDMI.
Jan 20, 2011 | Yamaha RX-V2600 Receiver
How to connect an Xbox 360 to an RCA RTD205 System?
you can turn every thing into surrond sound. all your visual componants, i.e. x-box, cable, dvd player and so on. connect directly to your tv, right? if so go to your local eltronics store and get youself an optical cable, typically $50.00 or so depends on the length. Go home with that cable connect it to the optical out on your tv and optical in on your reciever, (stereo) and bam all componants are now linked to your surroun sound. Dont forget to post your satisfaction. Be sure you have optical in and out before you go buy this wire. For god sake do not kink this wire either or you will have to buy a new. There is glass inside of optical wires, that transmits the light that the sound travels on.
Feb 25, 2010 | RCA RTD205 System
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Yamaha YSP-1100 Main / Stereo Speaker Logo
244 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
