Question about GE 2-9096GE1 Caller ID Unit Phone
GE 29096GE1 Caller ID
Can someone please tell me how to set up this item? I changed the batteries & now all it displays is the timer....
SOURCE: No caller ID information for GE Caller ID phone ( Model # 29385GE1)
I must have gotten your unit. Mine did work ONCE after it had been installed for about a week. But it never worked again and we pitched it. Buy something else.
Posted on May 04, 2008
shaggyrat
  • 1224 Answers
SOURCE: Phone does´nt caller ID in Brazil
some countrys still dont have the call id upgrade you know example fiberoptics and with new phone its a win loose situation till they catch up
Posted on Jun 02, 2008
SOURCE: The display doesn't show the caller ID
probably your phone have a incompatible call ID system (probably FSK), and your line is DTMF. Needs a standard converter, from DTMF to FSK.
Posted on Sep 02, 2008
SOURCE: cannot setup caller ID
Have you tried this web site?
http://www.retrevo.com/support/GE-29267GE3-Telephones-manual/id/512bh032/t/2/
Posted on Jun 02, 2009
SOURCE: Caller id display screen
I can't read my caller Id Screen numbers are disappering
Posted on Jun 18, 2009
How do I turn on my self timer on my d40?
I'm going to assume you mean a Nikon D40. If I'm wrong, please reply to this post and enlighten me.
Press the [info] button to bring up the information display. Press the [i] button to put the cursor into the display. Use the multiselector to select the Shooting Mode (fifth item from the top, along the right edge of the display) and press the [OK] button. Use the multiselector to select the self-timer mode (one-handed clock) and press [OK]. Start the self-timer by pressing the shutter release button as usual.
You can change the length of the delay with Custom Setting 16.
Mar 16, 2011 | Cameras
Where is the timer button on the Nikon D5000?
It's not one button.
If shooting information is not displayed in the monitor, press the [info] button. Press the [i] button to place the cursor in the information display. Use left/right on the multiselector to highlight the current release mode in the information display (the fifth item from the top along the right edge) and press OK. Select the self-timer (the one-handed clock symbol) and press OK. Custom Settings #C3 controls the length of the the timer delay.
Don't forget to change it back when you're done.
If you use the self-timer a lot, you can program the Fn button on the front of the camera to set the self-timer.
Dec 06, 2010 | Nikon D5000 Digital Camera
I programmed the timer as instructed but when the time to turn on came it didn't turn on. I changed the mode to "on" & it turned on but I don't think it will turn off automatically. What...
You posted under Woods outdoor 2-outlet timer 59403:
Add a comment if this is not your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Lets run through trouble spots others have with programmable timers:
Add a comment any time and I will help.
What we know for sure:
-Battery is working because display shows.
-Manual override works, so basic electricity is OK and light is OK
-Common programming problems:
-You set current time and it shows in display > if current time is not set or does not advance with passing time, then timer does not know when to turn on-and-off. Double check display for current day, hour, and minute.
-Each event has ON time and OFF time. So you set event1 ON and then set event1 OFF. For example some people set ON time and don't realize each ON needs corresponding OFF, or can't find how to set OFF. Trick is making sure timer display matches fig3 and fig4 shown in manual. Press PROG button until display shows 1ON for event1 ON and then press PROG button until display shows 1OFF for event1 OFF.
-To review programs and double-check, press PROG button repeatedly to scroll through programming. Check for ON and OFF days, and for overlapping on-off commands.
-Event1 ON and event1 OFF should be set for same day(s). For example event1 ON is set for Tuesday but event1 OFF is set for All-days (instead of Tuesday) will conflict and timer will not function.
-Conflicts in programming will cause problems. Conflict example: Event1 says ON 7pm OFF 9pm Tues, but event2 says opposite.
-Make schedule of on-off times before programming to avoid conflicts.
Setting Mode:
MODE is manual override button: press it to set Automatic, ON-OFF override, or Random
Press MODE button until RDN displays in upper left corner, and then press MODE one more time to enter AUTOMATIC >>> you want automatic for programming functions.
Circuit analyzer: If above items check out 100%, and timer still doesn't work, plug timer to indoor plug on another circuit (not on outdoor plug). This will check if outdoor plug has electrical problem interfering with electronics inside timer. Buy cheap plug-in circuit analyzer from Home Depot electric department and double-check circuits.
59403 manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
Nov 27, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
How do i programm 735 t6 timer prince castle timers
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Oct 08, 2010 | Prince Castle 740T2 2Channel Single...
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 05, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Please could you tell me how you change language from french to english on a samsung jet please
touch menu icon @ display screen bottom right, enter settings with an icon like a blue circular saw, enter phone settings with phone icon on the left (item 4 in the menu). Language is the first item there, enter it and select english then save. good luck
Sep 24, 2010 | Samsung Jet S8000 Cell Phone
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
Boot light staying on on display
Might have to get the computer reset. The code is probably locked in.
May 24, 2009 | 2004 Ferrari 575M
Programming items
Hi.
To change a standard keyboard PLU (item):
Turn key to program mode.
Press 2 SUBTOTAL. You should see 'P2' on display.
Type the new name using the alphabet sheet - usually under your normal keysheet.
Press 00
Press the item button to set the name on it.
Press SUBTOTAL to finish.
To change a price,
Key to program mode.
1 SUBTOTAL. You should see 'P1' on display.
Type new price with NO decimal point.
Press item to set price on it.
Hope this helps.
Mark
Oct 16, 2008 | Casio Parts Cash Register PC Desktop
GE 2-9096GE1 Caller ID Unit Phone Logo
179 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
