Question about Cell Phones
Vodafone 625 that shows as paired & active phone but doesn't work
Bluetooth showing on on the phone. Phone successfully paired. Ford Audio shows no phone
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
When all else fails read your owners maual a\or call the dealer they can usualy walk you through it over the phone
Posted on Jul 30, 2009
Pair iphone to general motors car
  • Get into your GM vehicle with your Bluetooth compatible cell phone and turn both on. Use the dashboard controls to turn your GM's Bluetooth system to its "Discovery Mode."
  • 2 Go to the Bluetooth application on your phone and turn the Bluetooth mode on to its "Discovery Mode." Now your phone will begin searching for other Bluetooth devices within its range. When it locates your GM's Bluetooth, your phone's screen will show the name of your vehicle and ask if you'd like to continue syncing the two Bluetooth devices. Select "Yes."
  • 3 Enter the numeric code that appears on your GM control panel screen into your phone and continue the pairing process. While pairing, your phone will share your contact information with your GM to enable the Caller ID on the dash screen to work.
  • 4 Confirm successful pairing by making a phone call. Make calls using your GM's voice activation, which is done by pushing the "Phone" button on your steering wheel. You can also dial from your phone's keypad and the sound will transfer to your GM's speakers.
  • Jan 23, 2014 | Apple iPhone 5
    Why I can't bluetooth pair with veho VSS-006-360
    Hope it helps.
    Power off your N8.
    Remove battery from your N8 and reinsert again and then power it back on.
    Activate Bluetooth settings and program it to become discoverable
    Power off your bluetooth speaker
    Remove battery from your Bluetooth speaker and reinsert.
    Power it on again
    Allow the pairing to proceed for both devices. Check and confirm/test whether operational
    Oct 17, 2017 | Veho Audio Players & Recorders
    Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
    your limit would have crossed
    there are a particular no of devices that could be paired
    Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
    1. From the Home screen tap Menu > Settings app.
    2. Tap Wireless & networks.
    3. Tap Bluetooth settings.
    4. Ensure that Bluetooth is checked.
    5. Turn the Bluetooth device on and set it to discoverable if required.
    6. Tap Scan for devices.
    7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
    The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
    Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
    How do i set the blue tooth settings on my nokia c3
    From your phone's menu, select 'settings'.
    Go to 'connectivity', select 'bluetooth'. Under the bluetooth menu, you would see the following sub menu
    1. Blue tooth
    can be set to either 'on' or 'off'.
    2.conn. to audio access - you select this if yuo want to connect your phone to a bluetooth earpiece.
    3. Paired device
    under this, you would see 'add
    new device'. You select it if there
    is a new device you want to add.
    4. Active devices - it shows any device that is active.
    5. Phone visibility.
    Select 'always visible' if you want
    your device to always be visible
    to any active device.
    Select 'temporarily visible' if you
    want to be temporarily visible.
    Select 'hidden' if you want to be
    hidden. To other devices.
    6. My phones' name. Select this to change your phones' name from the default to any name of your choice.
    Hope this was helpful? Please do indicate. Success.
    Apr 11, 2011 | Nokia C3 Cell Phone
    I have a Ford Fiesta with a model 6000cd radio in. im having diffculty pairing my mobile phone to the radio. i pair my old mobile successfully but cannot remember how, i think i had trouble last time...
    Try to un-bond all devices in the menu first it may be that the device list is full.
    it should say un-bond in the menu. then try to search and enter the code that shows on the screen when you bond your phone
    Hope this helps
    Feb 13, 2010 | Car Audio & Video
    Bluetooth activate error
    HI,
    Please pair the device with the phone? if not then read the manual of the bluetooth and pair them first.Also try turning the cell off & removing the battery and then turn oin again to see if the issue is solved.
    Feb 10, 2009 | Samsung SPH-M610 Cellular Phone
    Motorola h710 bluetooth will connect to phone but no audio
    I disabled the bluetooth from my phone. I then turned off my phone and rebooted it. Once the phone was turned back on, I paired it up with the bluetooth and then it worked. So disabling and removing everything and starting over worked.
    Feb 03, 2009 | Motorola Mobility H710 Bluetooth Headset
    I need a instruction maual for a itrax bluetooth device
    Pairing With A Bluetooth Enabled Cell Phone
    1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
    (1 metre).
    2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
    The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
    3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
    BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
    follow the manufacturer's instructions for that device.
    4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
    5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
    6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
    3 seconds.
    Nov 24, 2008 | Cell Phones
    Cell samsung SGH-F250 with bluetooth motorola h500
    ACTIVATING THE BLUETOOTH
    You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
    between your phone and your SuperTooth kit as well as with other Bluetooth devices.
    1.
    Press Menu > Settings > Bluetooth > Activation > On.
    2.
    Press Back as many times as needed to return to standby mode.
    PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
    Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
    1. Bring the cellular phone at about 20 cm from the SuperTooth.
    2. Turn off the SuperTooth and wait for about 4 seconds.
    3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
    4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
    5. Highlight SuperTooth then press Select.
    6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
    7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
    The SuperTooth kit is now ready to use.
    Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
    How to program bluetooth phone to sony radio cd player
    Ok, I have a Sony MEX BT 2600. To pair my phone to the radio, I had to press and hold the BT button for 5 seconds until it flashes, then I have to search for devices on my phone. Xplod comes up. When it does, pair the two and use code 0000. That should do it. Also make sure the BT icon is showing, meaning it is activated for the Sony to connect. When conncted, the radio should show a phone icon for the BT Phone segment of the radio, and then another icon for the BT Audio, both should what looks like radio waves coming off of them, meaning the two devices are connected and recognizing each other.
    Oct 26, 2008 | Car Audio & Video
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
