Question about Sony KV-20FV12 20" TV
TV is in stanby/timer?
A friend of mine gave this TV to me. It's light stanby/timer on TV is flashing all the time. I can't get the TV to come on either by remote or TV. I have tried a few things but no success. Can anyone help. Please email me at
  • 934 Answers
There are any number of things could be wrong here. If you have an ever so slight chirping sound coming from inside the unit when you press power could be defective crt driver Ic702 which is a Tda6108 and a common problem for these sets. Could be regulator or flyback and could even be vertical Ic which is a Tda8172 and just the way that circuit is designed, without full deflection from a failed Ic, the shutdown would keep the power off...
Best advice here is take it in to a qualified shop and have them estimate it, you'll be money and headaches ahead..
Posted on Nov 24, 2007
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
Hi Frank,
Please let me know if it has a pattern of blinks (separated by a pause) or it will flash an exact number of times. Your unit (KV-34HS420) has a built in self diagnostic software that will indicate the probable caused of the fault by flashing of the LED at the front panel.
Nov 30, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Stanby timer light blinking
you need the V26 DM kit which will usually cure that issue. Its chaep and contains the Replacement capacitors and step by step instructions. Heres a link to the correct kit.
Jun 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Light bulb flashes 3 times, TV won't turn on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bud news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois
Aug 30, 2008 | LG 52SX4D 52" HDTV
Red timer light flashes but will not turn on green timer light flashes when plugged in. No buttons on remote or tv work. Tv will not turn on or off.
hay chap i have a front projector mad by the same company . u have probably owned this awile now and noticed its dimming a bit but still watchable . these sets are a pain cause even thought the bulb is good it will give u the red light of death . this means the computer in your tv is saying its time to change the bulb . mines doing the same . i know it sounds stupid and trust me it is but thats what it sounds like . what i have been planning to do to mine is pull the bulb out and put it back in to see if it resets the timer on ther computer for the bulb life . i could be wrong friend but thats what i would have to figure it to be . let me know if i was any help.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Kf60xbr800 internal lamp component, what is the replacement costs for such parts
Go look at your set up timer in menu see what it says some sets will tell you to replace lamp, while other types of DLPs just start turning off and on ,their may also be something wrong with area around lamp too.Read your service manneul or get one on service . ThankYou for using FixYa.Have a Nice Day.
Feb 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Won't turn on
Make sure that you have the orange flat cable turned the right way when you plugged it in. I accidentally turned one the wrong way and that was the response I got. Hope this is all it was if this does not fix it I would measure the ballast and make sure the 200 or so volts is coming across.
Feb 07, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Sony KV-20FV12 20" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
