I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
Cool light on
dry light flashes
heat sensor light on
dryer not heating
Maybe your thermostat or fuse are tripped...i think LG dryers have re-settable fuses and thoermostats...you need to getthe fron panal aopen and check in the heating compartment for them...check if they have re settable fuses or thermostats. if they do they will have buttons you can push..push them and see if any of them click...
My lg #dlg3788w dryer kinda humms when i turn it on and the drum wont spin, so i took the top lid off and help push start the drum and it turns, then put some towels in it and its seems like there is too much weight it and it wont turn at all, already changed the belt (though it was stretched out) any help would be appreciated.
thanks john
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
i called lg tech, he says to pull out the vent and inside it behind are two sensors, to clean them with warm gentle soap on a rag, that if you use dryer sheets it will get a build up on the sensors. he says we are not to use dryer sheets with these dryers!! fabric softner in the washer machine.
What do the sensors look like?
White with two wires coming out of one side.....
