I have a Rheem Model # RAMB-030JAZ that the fan will not come on when the A/C is turned on and does not produce cold air. Is there a common electrical problem for this model that would prevent it from coming on?
  • 614 Answers
The unit has a fan relay that sometimes goes bad. Check to see of fan is hot or tryimg to start. Might be bad capacitor. Fan relay or relay boards are easy to change.Russ
Posted on Jul 31, 2009
I have two units, Rheem 10 seer Model RAKA 030jaz Model RAKA 024JAZ Technician says both need to be replaced, bad compressor. Can I go with in large system or can I replace compressors in each? House is...
The probability of interconnecting two separate duct networks designed to properly distribute proper air flow with their own air handlers is remote. Is it possible?? Yes. Is it going to work perfectly ?? No. Even if it did, the noise level on a ten ton air handler would be very undesireable in a residence.
As a matter of fact, it may not even be possible depending on how the structure is laid out. A two story with a system in the attic and one in the basement isn't going to interconnect easily for instance...
Mar 11, 2015 | Heating & Cooling
I have a Rheem RAMB-036JAZ compressor . I just had a preventive maintenance check-up with it . The technician cleaned out the unit and checked the freon and it had been running fine all summer until...
sounds like a bad run capacitor. Its the big round silver thing. You have to get the same micro Farad rating as that one. Easy to change its written on the cap Herm Com and fan. Just replace wires the same as they came off.
Jul 06, 2014 | Heating & Cooling
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
Rpnl-030jaz condenser fan not turning
if the fan does not run then it could be a bad motor or just the capacitor is bad. usually I check the capacitor first. it usually goes bad before the motor
Apr 14, 2014 | Rheem 2.5 Ton 13 Seer / Ruud Heat Pump...
Rheem RPKA-030JAZ MAKES A HARD KNOCKING SOUND
sounds like it's running backwards. possibly need a time delay in the condenser. make sure your drain line is clean.also inspect low voltage wires for bare/ chew spots near outdoor unit.
Oct 12, 2017 | Heating & Cooling
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
Apr 12, 2017 | Heating & Cooling
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
I am trying to determine the specs on my Rheem Criterion II lx2000 heating/AC unit unit installed in Sept 99, I blieve it was manufactured 2/5/99 based on AC Pump serial number 6263F259928697 Model RAMB...
rheems site is secure for dealers only but i can tell you. its a 3 ton unit 12 SEER R22 unit. The coil (rcga) is a 3 ton coil The AC is a 1999 and coil 1998. the # you have for the heater is accually just the honeywell gas valve. the model for the heater would be on the inside wall near the gas valve.
Sep 19, 2009 | Heating & Cooling
Heating & Cooling Logo
1,173 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
