Question about LG 42PC5D Television
LG LC55 humming/buzzing
My lg lc55 makes a humming /buzzing sound when its switched on,its really annoying when the sound is low.it comes from the left hand side of the tv(when facing the back of the tv).didnt know if it was a fault or just a noisy product like my xbox360...
  • markvark Jan 22, 2008
    i have the same model & same electrical humming/ buzzing noise. it appears to be coming from the area where the power cable goes into the tv. funny thing is the noise tends to be present when watching through DTV input, AV1 input (sky box) & AV2 input (vcr) but is not present when playing nintendo wii through component input. i have had the panel 3 months but have only recently noticed the noise, but thats not to say it hasnt always been there.
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Posted on Mar 12, 2008
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
LG fridge making loud noise
Bonjour,
jeepers are we talking about a wheeze, a clunk, a whirr, a buzz, a rattle, a hum, random modulated or cyclic, low or high frequency, persistent or intermittent? Or could you just be hearing fan noise.
If it sounds like tin pieces clinking against something metallic. The fan blades may be striking ice or frost or the shroud.
Could be a bad or worn fan motor bearing, or a defrost problem causing frost build up.
Just a FYI
Some LG models have been reported online as having many many operating issues.
Hope this helps
Jul 11, 2012 | LG Refrigerators
How to fix sound on my lg 42
Some simple things you may already have tried but I will list:
Unplug set for a while and then plug back and see if sound--when unplugged the set may reset.
In main menu make sure speakers are not switched off.
I doubt it is mute but if also using some type of box check that its volume is not all the way down.
If internal speakers put your ear right to them---hear low sound or a buzz or hum?
If using external speakers of any kind look at the hookup and switch to make sure internal/external is correctly selected
If NONE of these help you have an audio problem and should first contact LG (yes it takes time on the phone) to inquire if some common issue or a possible software upgrade is available for this.
Last: Some failure has occurred either in the audio circuit or something that feeds it.
Mar 22, 2012 | LG Televison & Video
Lg lcd tv humming sound which varies throughout a programme no rhymn or reason to it but especially noticeable when quiet part of programme
Alot of Tv's have this sound that comes from the speakers or the back of the set. Its normally when the transformers inside are underload they start buzzing. this could come from the Powersupply or the Inverter. When changing channels they change their tone sometimes.
Mar 22, 2011 | LG 32LG30 32 in. LCD HDTV
LG Voyager keyboard backlight broken
The connection between the keyboard and the mother board are loose. You need to take the phone apart and push the connection all the way back in. the connection is also connected to the screens and that might need a good push. Ive done this fix on many LG voyagers and enV's.
Jun 10, 2010 | LG VOYAGER VX10000 Cellular Phone
Icemaker on LG LFD25860ST not working.
Sounds like the hot gas defrost solenoid is enegised. the contoller for this may be at fault.
Apr 17, 2010 | Refrigerators
LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Feb 08, 2010 | LG 42LH30 42 in. LCD TV
New 42LG30 - 42
This is probably a defect in the backlight inverter circuit. The transformer may have a loose winding or something in there is not cycling off or on properly. If you can still collect on the warranty, do so.
May 19, 2008 | LG 32LC7DC 32 in. LCD HDTV
Lg lc55
i have lg 42" lc55 model and had the screen smashed any ideas if it can be replaced!!!!!!!!!!!1
Jan 11, 2008 | Televison & Video
Televison & Video Logo
1,292 people viewed this question
Computer Repairing
Computer Repairing
