Question about Fagor 24 in. FI-48W Dishwasher
My fagor dishwasher is not emptying properly, Water is left in the bottom . It went alright till it was moved when renovating the kitchen. It about two years old, and is the Innova model IVF-25IN
  • 11,896 Answers
Drain or screen is contaminated and the newer machines are really touchy.
1) Be sure the drain hose isn’t kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The water pump may be broken or clogged with a small article of clothing, or the controls may be broken; call an appliance repairperson. GA_googleFillSlot("HT_Appliances_Clothes_Washers_Articles_Referral_BL_181x151"); GA_googleCreateDomIframe('google_ads_div_HT_Appliances_Clothes_Washers_Articles_Referral_BL_181x151' ,'HT_Appliances_Clothes_Washers_Articles_Referral_BL_181x151');
GA_googleFillSlot("HT_Appliances_Clothes_Washers_Articles_Referral_BR_180x150");
Posted on Aug 01, 2009
My Fagor dishwasher di not finish the cycle and has water in the bottom of the machine which has not drained. Now it will not start and just beeps. How can I drain the water and get it to start and fu
A small amount of water in the bottom is normal (it allows the pump to be pre-primed). Do not remove the water (as long as it is only a little in the center well).
Nov 03, 2014 | Fagor Dishwashers
My Fagor dishwasher won't fill.
Check the water in-let electrovalve, could have dirt or the coil damage
Apr 30, 2014 | Fagor Dishwashers
Water in dish drawer
Depending on how much water could be collecting it might be normal. If this is causing the dishwasher not to clean the dishes properly then you may need to clean the filters and ensure the kitchen sink drain is clean.
Jan 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fagor F1-48W dishwasher won't fill
this must be a water flow problem to machine , id look real carefull at valves under sink or under floor of machine to see that there open and there are no kinks in hose connecting to it , other than that the one only other reason that it would not add water is that it thinks there's water in it already
Dec 21, 2012 | Fagor Dishwashers
Water left in bottom of tub after washing and drying.
machine is not pumping out if controls are ok,then i would suspect pump needs replacing.adrian,,,,
Jul 14, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Water collecting at bottom of dishwasher. screens have been cleaned.
is there water sitting in the bottom of the dishwasher or on the floor? If its sitting in the bottom of the dishwasher, most likely the discharge pump isn't working properly and not emptying all the water out. The pump will usually run for an extended time to pump the water out until it finally times out and you're still left with water in there...
Sep 09, 2009 | Dishwashers
Bosch dishwasher S10R1B: Water not pumped out
Normally it is the impeller which is stuck. Take out the dishes and the filters and empty it for water by hand. Yes it is a dirty job. Then at the bottom there is an opening in the steel where the water is collected. Empty this too. At the bottom left there is a torx20 screw that keeps the cover for the impeller. remove the cover and check that the impeller can move. The may be object stuck
You canalso force the safety mechanism in the door with a screwdriver and try to see if the impeller moves when it is supposed to empty water.
My problem is that I did all this but it still does not move. It may be the impeller motor which is broken. To replace that one is not easy.
Jan 31, 2009 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Works then no power Kenmore 16352
first thought would be a loose connection in the junction box under the dishwasher.
Nov 27, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Fagor Dishwasher FI-48w Replacement Parts
Angelo,
We are the manufacturer; Fagor Commercial, Inc. We have a network of parts distributors for our products. contact us to provide you with the most convenient one for you.
305 779 0170 or 1-866 GO FAGOR
Thanks
Jul 04, 2008 | Fagor Dishwashers
Fagor Dishwasher
ok if you have a volt meter then remove the bottom kick-plate locate the water valve take the connector off the valve set the meter to ac volts plug the leads into the connector turn the timer to fill if your getting the proper volts to the connector then replace the valve if nor reply to me
Jun 11, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
235 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
Tom Chichester
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
