Question about Whirlpool Heating & Cooling
The electricity went off this morning and now the air conditioner is blowing warm air and I don't hear the compressor coming on its a whirlpool window unit Thank You
  • 69 Answers
Turn the unit off for 5-10 mins. turn thermostat to coldest setting then turn unit back on. see if the compressor kicks on in a minute . it may need to reset itself.
Posted on Jul 30, 2009
Good evening all, This morning woke up to my home
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Aug 31, 2013 | Whirlwind FH-778 Air Conditioner
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
My air conditoner blows cold for maybe 15 minutes than warm
Are you using a "very powerful" AC to cool off a relatively small space? The AC has a thermostat, if the return air is meeting set point, the compressor would stop. The fan could still be circulating, hence the perception of warm air. What you should do is don't block the ventilation, and direct the cold air toward the ceiling. The cold air will sink (due to higher density) and create better circulation and temperature mixing.
Jul 19, 2011 | Whirlpool Heating & Cooling
Problem with heating and air conditioning. The driver's side is blowing hot air and the passenger side is blowing cold air
Air Conditioner blows warm air
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
Jun 01, 2011 | 2004 Buick Century
We have a Brisk Air in our 1991 Jayco Eagle. The travel trailer is from Rhode Island and we're not sure if the air was ever used. The unit turns on, the compressor engages but doesn't blow cold air, only...
Really sounds like the compressor isn't coming on. Go on top of camper and take the housing off. Now then engage the air conditioner and feel the compressor. Touch the copper lines to feel any temp. change. Now then if it isn't coming on look for the capacitor. Silver looking can that is the item to check. They are duel purpose they run the fan and the compressor. Unplug the electricity and remove the capacitor remembering the wires and were they went. Now take to parts house and they will be glad to check it. Should only cost about 15 bucks for new one. Get the same rated size. be good to go. ken
Sep 15, 2010 | Dometic Rooftop RV Air Conditioner
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
My a/c unit does comes on but it only warm air not
Make sure the outside unit is running, compressor and fan. Sometimes it is hard to hear the compressor over the fan. If the outside unit is not working check circuit breakers first. Set thermostat to call for a/c and make sure the contactor in the outside unit pulls in. If it does check capacitor for whatever is not running. If everything seems to be running fine hold your hand above the fan outside. The air coming from it should be hotter than the outdoor air. If it isn't get the refrigerant charge checked.
Jun 29, 2010 | Goodman GPC1342H21A Air Conditioner
Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Oct 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Heating & Cooling Logo
239 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
