Does this A/C have the ability to take in air from outside in the "fan" setting? Or does it just recirculate air from inside the room?
Comments:
Jul 31, 2009
- It does not have a flap that I set, but the manual says to make sure that the valve is set open for the fan to get fresh air into the room, so I was a little confused by that. Must be for another model. Thanks for the reply.
Not sure but check to see if ahs a fresh air intake. This is a manual flap you have to set it yourself. If it does not say fresh air. You dont have one. Russ
Just purchased a 15000 btu 110 Frigidaire window unit and we love it. However, since the rear of the...
(More)
Just purchased a 15000 btu 110 Frigidaire window unit and we love it. However, since the rear of the AC is actually on the back porch, the water from the AC runs down the wall and on to the floor. We could not find in the manual anything about a place to attach a drain tube nor did we see evidence of one on the unit itself. Our house is wooden and susceptible to termites. How do we funnel the water from the AC to the ground? Is there a separate attachment for the AC? How do we funnel the water from the AC to the ground? Thanks,oliver f. mckinney
the air unit does not blow cold air, it blows a little cold air, but not enough to keep the room...
(More)
the air unit does not blow cold air, it blows a little cold air, but not enough to keep the room cool. does the unit needed to be shot with freon?
