Question about Lexmark C720 Laser Printer
Lexmark c720 color laser printer
Was having problems with the paper not feeding from tray one (this printer has only one tray). I bought a new printer tray for the lexmark c720 and had the same problem. I cleaned the rubber feeding roller and that fixed the paper feeding problem. The next time I went to use the printer I got the message tray 1 missing. I re-inserted the paper tray and tried the other paper tray that I had and got the same message.
I have the service manual for the printer and looked up the message - Tray 1 Missing, and input tray is missing from the printer. They said to check the tray, the cassette set sensor, and connectors DCN6 and DCN8. I had already checked the tray and it was fine, but I could not find in the service manual where the cassette set sensor was or the connectors DCN6 and DCN8 are.
The copier has not been used that much over the past seven years, has 18000 copies on it.
Any help or suggestions you could give me would be much appreciated.
Thank you,
Rodger
    President:
  • Lexmark Master
  • 1,447 Answers
Please chack it feed claught unite
thanks
Posted on Jul 31, 2009
I don't have a owners manuknow how to change the paper trays from
Go to Menu, then Paper Menu. Select Paper Source then select Manual Feeder. You should also select manual feeder from the driver.
I'd like to add the link to download the User's Guide for future reference. http://www.lexmark.com/publications/pdfs/optram410/enUser.pdf. Hope this helps. Leave a comment if you need more assistance. Thanks.
Jun 29, 2010 | Lexmark Optra M412 Laser Printer
Will the Lexmark C720 print with only the black
There are some Lexmark color laser printers that are capable of black-only printing w/o the color cartridges installed, unfortunately, the Lexmark C720 printer is not capable of printing with only the black cartridge installed.
Jun 02, 2010 | Lexmark C720 Laser Printer
We use a Lexmark E332n laser printer at work. When someone attempts to print something, the printer jams with a problem with the paper feed coming out of the tray. It essentially folds up on itself and...
try cleaning the feed wheels with a arisole electronic contact cleaner these get a glue composite build up on them and contact cleaner will remove it with out leaving behind any residue and make sure that the paper guides in the tray are not set against the paper to tightly. i have also seen these pick wheels (the rubber tire) be so loose on the shaft that they slip causing this problem.
Nov 19, 2009 | Lexmark E332n Laser Printer
My Lexmark C510 keeps saying paper jam and has hardly grabbed the paper out of the paper tray. Also says "short paper". I called Lexmark who told me that I needed two parts: a paper feed roller (56P1655)...
If service were required, Lexmark would have offered to place the service call for you.
Go ahead and order the parts, if they look to complicated to install, then you can place a service. Most "C" level color lasers require on-site service and should not be taken to a dealer.
Don
Jun 03, 2009 | Lexmark C510 Laser Printer
Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Jun 01, 2009 | Lexmark E232 Laser Printer
Lexmark Opra M410 Laser
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
Jan 06, 2009 | Lexmark Optra M410 Laser Printer
I have a laser jet printer HP color laserjet 5500 and lately i have noticed an increase in the number of times i have paper jams problems.what could be the reasons?
Hi dwigling:
You may need a new set of feed rollers. Check you feed rollers in the paper tray and if they are smooth you need to replace them.
Dec 02, 2008 | HP Color LaserJet 5500 Printer
Printing envelopes
you can replace the paper in the main tray with the envelopes. this is the only way unless you have a secondary paper tray or manual paper feed that does not override the main paper feed
Oct 03, 2008 | Lexmark Optra T610 Laser Printer
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
Lexmark C720 Laser Printer Logo
222 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
