Question about GE GSH25JFR Side by Side Refrigerator
I am removing the back panel of the freezer because something with the defrost isnt working. Freezer has ice/frost build up. hany tips on how to defrost from here until the repair guy can come around?
  • 1,305 Answers
One easy way is to unplug it and let it thaw out on it's own... get a couple ice chests and put you food in them and unplug it overnight...works wonders!
Posted on Jul 30, 2009
Refrigeartor not chilling, freezer not freezing
If you have built up ice inside the freezer walls, and the defrost assembly isn't functioning, this could be the problem.
Defrost the unit! Take all the food out of the freezer side, remove shelves; remove inside back panel. If there is a lot of ice build up there, then your defrost assembly is not working or your refrigerator is not a frost free unit. Defrost either by leaving the freezer door open over night or you can speed the process up with a hair dryer. Once the ice build up is dealt with, you can plug the refrigerator back in and see if it will now freeze the freezer and chill the refrigerator. If it does, and you have a defrost assembly you need to order it and have it on hand when the ice builds up again.
Jun 05, 2011 | Refrigerators
FRT221RSH refrigerator warm...freezer cold...some frost on back of freezer wall, i popped off the small cover on the inside back wall of the freezer and the fan there is running...i vacuumed a little dust...
If you remove the entire back panel of the freezer section there is a evaporator (aluminum grill looks like a car radiator, contains r-134a, do not puncture or unit is ruined) Some frost on back freezer wall, means probably this entire grill is encased in frost, not allowing any air flow, which is how the entire refrigerator section is cooled, by air flow) The frost build up has to be removed,(got a hair dryer) you can unplug it for a couple of hours with the door open, overnight is better,this would fix the problem for a couple of weeks....Your automatic defrost is not working, there are three parts- the timer or control board, a heating element, and a bi-metal thermostat(often the problem)
You popped off the cover for the ice maker, you need to defrost the whole freezer section behind the back panel. Freezer cold means your compressor and freon are fine, you have a defrost problem with ice build up restricting air flow. A normal automatic defrost runs every 8 hours, three times a day, rule of thumb.....Sounds like you have a couple of weeks built up...........
hope this helps
Feb 23, 2011 | Refrigerators
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fan in freezer very loud noise
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Feb 01, 2009 | Freezers
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerator
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Oct 05, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
GE GSH25JFR Side by Side Refrigerator Logo
274 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
