Question about LG 24 in. LDS 5811 Built-in Dishwasher
How can i clean out the drainage hose on n lg dishwaher model lds 5811BB
  • 1,305 Answers
First of all, disconnect the electrica plug under the sink. Then you can remove the kickplate cover on the washer and you can access the hose to remove it.
It most likely goes to an "air gap" on the sink. That's the noisy vent is typically located to one side of your faucet. alot of times, that's where the drain hose will get blocked. Take the large hose loose from this first to check for blockage and build up...
Many times the blockage can't make it thru the air gap...
So if you clean that , you're probably have got it all.
K
Posted on Jul 30, 2009
What do i do to fix error code OE on my LG dishwasher
Based on what it mentioned on the LG website it is an error indicating a drainage error. The solution might be to clean the drain filters at the base, check drain hose under kitchen sink and behind dishwasher for kinks or blockages. On make sure the kitchen sink drain is not blocked. Worst scenario is a clogged drain pump. you will have to provide the model number for any further analysis.
Sep 19, 2014 | LG Dishwashers
Small Drainage hose replacement
if its not damage no need to replace ,after filling water inside the drum,,pull out it & clean with some metal wire...with the water all the dirty will come out,,
Apr 15, 2014 | LG WM0642H Front Load
LG Dishwasher LDS 5811BB does not turn on when pressing the Power button.
1. confirm there is power up to the dishwasher.
2. open electrical connection box on right side, behind toe kick panel, and hold one wire nut connector at a time while giving each individual wire a firm tug. All wires should remain connected. If not, correct poor connection.
3. dissassemble door and check door switches.
4. if all previous steps check out, you should have a red LED lit on the control board inside the door. If power to board, but no LED on, replace board.
Jan 15, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
My dishwasher is an LG LDS 5811WW it reports an IE reading after one minute. Any help?
check clogging of water inlet hose ( or hose twist or freezing)....check water supply
Oct 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Door leak on built in LG dishwasher.
Check and make sure the unit is level front to back and side to side.
Check all 3 spray arms for plugged or restricted holes that may be diverting water in the wrong direction..
Jan 05, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg LDS 5811st IE code
With an LG 5811 diswasher, when the IE error code is not caused by kinked hot water hose or blocked screen, the next step is to measure the electric resistance of the Inlet Valve. (950-1300 ohms)
Dec 05, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Just purchased an lds 811bb returned to store because of scratch. does not have an either a installation guide or a users manual with it. can you help?
I see you meant to say LDS 5811BB in your message,. The User manual and a relevant installation Guide is posted in the All Products / LG / 24in LDS 5811 Build-in Dishwasher section (click on the link above and scroll down to the manual and Guide area. OK?
Nov 27, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
OE blinking
Hi
I have the same machine and OE means drainage trouble.
  • Check clogging of water drain hose (or hose twist of freezing)
Cheers
Aug 01, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Drainage problems
i believe there should be a flap that closes the vent during the wash and opens while drying. this is inside the door the motor is possibly bad
Dec 09, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
180 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
