Question about KitchenAid KERA205P Electric Kitchen Range
We have a kera205 kitchenaid range. The simmer switch isnot functioning. How do I fix it? reset breaker, install fuse?
  • tasargent Oct 16, 2009
    The design of the simmer switch is faulty. When the burner is on, full current is going by the switch. When you turn the simmer switch on, the full current flows through the switch and can't handle it. It blows the switch. You have to turn the burner off, turn the simmer switch on, turn the burner back on, then the simmer switch won't blow. How does anyone cook like this, I don't know? Just a marvel engineering effort on Whirlpool's part. There's supposed to be a beefier simmer switch to replace it but I don't know the part number.
4 Suggested Answers
the dr
  • 447 Answers
SOURCE: Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
Model KERC500Y Standing in front of stove the Left front
burner won't heat.
Posted on Mar 24, 2009
SOURCE: Kenmore Electric Range Model 790.96224406 I'm
Same problem (and it started over xmas...what a coincidence). Replaced the switch and no luck. Bought another eye (used one on ebay) and no luck. I need to stop shotgunning and bring in a voltmeter. I'll let you know if I find anything. Have you figured it out?
Posted on Jan 23, 2011
I have a kitchenaid YKESS907SS00 and the front display and all functions of the oven do not work. The range works fine. I need help to troubleshoot what is wrong with this darn thing.
I brought the schematic remove the front panel be sure to unplug if you know to use a meter you need to check continuity thru the thermal cutoff and thermal switch if one is found to be open then there is no power going to the control board
Feb 14, 2015 | KitchenAid Kitchen Ranges
One burner on Kera205pbt won't heat
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
Feb 08, 2013 | KitchenAid KERA205P Electric Kitchen Range
Burner turns itself off on KESA907
Most likely the switch that controls that burner is the problem and needs replacing
Nov 11, 2017 | KitchenAid KESA907PSS Electric Kitchen...
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Gene
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
All power was lost after spark from oven light.
It sounds like it has thrown the breaker on your distribution board or a fuse if there is one. Remove the oven lamp and replace fuse or reset breaker. Don't forget to switch off the main switch before you remove/replace the lamp.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | KitchenAid KESA907PSS Electric Kitchen...
Kenmore Electric Range Model 790.96224406 I'm at my sister-in-laws for Christmas. This morning no burners would work. Cycled c/b and reset the clock. All burners now work except left front. (Left...
Dec 26, 2010 | Kitchen Ranges
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
My front burner not working.
Check to see that your simmer switch is in the off position, I just had the same problem and checked it back to the power connector and only had 120 V ????, I about to take the switch out and then saw the simmer switch that I never noticed. Clicked it to off and now my wife is happy again. Good Luck, hope your solution is just as easy.
Nov 07, 2008 | KitchenAid KERC500 Electric Kitchen Range
Sep 25, 2007 | KitchenAid KERC507 Electric Kitchen Range
KitchenAid KERA205P Electric Kitchen Range Logo
552 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
