Question about Praktica SlimPix Digital Camera
Flash When i take a picture in the house it comes out as white screen. Also a lot of my pictures are blurred
Re: Flash
My flash wont change. also the busy light on all time
Posted on Jun 12, 2008
Re: Flash
You may need to try using a different flash, if you click the flash button various times you may notice that there is different flash options.
Posted on Mar 09, 2008
0 characters
3 Points
When taking pictures outside or from inside through a window, the picture comes out white with faint red outlines of some images. Inside the house and darker areas it takes pretty good pic's. What can be...
First the camera has a flash to allow for darker areas to be illuminated to capture pictures. The type of camera may bot allow to capture outdoor pictures with the camera flash on. Power off the flash when outdoors to capture daylight pictures.
Jan 30, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
Picture comes out blurry and there appears a hand that appears to be shaking in the top left hand corner of the picture screen
Hand shake means shutter speed is too low to avoid blurred picture(due to low light)
Either increase lighting or
Use flash and turn it on or use higher ISO setting or
Use lowest aperture number.
Last when there is nothing moving in the frame you can use tripod at any P.A.S settings in any lighting
Jun 27, 2010 | Kodak EasyShare V1003 Digital Camera
Blurred pictures, and Red hand Flashing warning
The red hand is warning you that the shutter speed is too slow for handholding. Your pictures are coming out blurred because the camera is moving during the relatively lengthy exposure.
Put the camera on a tripod or other stable surface, and/or use the flash.
Dec 02, 2009 | Nikon Coolpix 3200 Digital Camera
When taking pictures they come out blurrie i try
Turn on your flash! Even in good lighting, shoot with the flash on. This will make your exposure shorter, and there will be less opportunity for movement of the camera or the subject to blur the photo.
Nov 10, 2009 | Vivitar ViviCam 5024 Digital Camera
Blurred pictures on fuji finepix J15fd
This is the camera shake warning, and thus the blur. It is suggesting you are using too slow of a shutter speed for the lighting conditions. The flash should be set to "auto" in order that it will automatically fire if the light is insufficient. Check your flash settings to make sure it's not set to "slow-sync" or "fill-in" settings.
Apr 06, 2009 | Digital Cameras
Blurred pictures
I had the same problem. The solution is in the manual but it is not straight forward. You have to set steady shot to auto when the shutter button is pressed half way down. The vibration warning will still show. At this point the camera is sensing low light. The to need to make sure the flash is set to always on. The flash setting for background will not turn the vibration warning off.
Dec 10, 2007 | Sony Cyber-shot DSC-T100 Digital Camera
Blurred pictures
try putting on the flash because whenever my flash is off the pictures are all blurred and with the flash it is clear! hope it works!!!
Feb 08, 2007 | Vivitar ViviCam 4345 Digital Camera
Blurred images with no flash
First, try to get more light, particularly natural light (window); second, try using shutter priority (S mode), setting the shutter speed at not less than 1/50, faster if you are shooting motion/action (check the Properties of the blurred pictures that you've been getting in Camedia software - the shutter speeds are probably too slow because of the low light), and experiment with higher ISO settings (either 200 or Auto, not 400) though there's a trade-off in noise levels.
Sep 11, 2005 | Olympus Camedia C-3020 Zoom Digital Camera
Praktica SlimPix Digital Camera Logo
80 people viewed this question
Top Praktica Digital Cameras Experts
Henk de Ruiter
Henk de Ruiter
Are you a Praktica Digital Camera Expert? Answer questions, earn points and help others
