Question about Hoover Vacuums
All tubes are clear but the Hoover spin brush won’t pick up water
  • 294 Answers
SOURCE: hoover steamvac spin brush puts
Check for the front panel duct located on the lower tank front. this is the part you need to remove to attach the hose. also check to make sure the lid is on and secure on the lower tank. remove the lower tank and look on top of the motor cover toward the left front corner you should see a round black gasket on a pipe. if not there, this will cause poor suction.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 18, 2009
SOURCE: My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Posted on May 27, 2009
fixdat22
  • 34 Answers
SOURCE: I own a hoover steam vac model f5915-900 and i
the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
Posted on Sep 12, 2009
  • 175 Answers
SOURCE: the brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Posted on Nov 28, 2009
SOURCE: My Hoover Linx is not
I think you have 2 problems:
1. The LiNX gets clogged somethings in the head unit and the clog is difficult to see. Remove the head (via the push button). and clean out the clog. I do this with a lenngth of coat hanger wire that I bent a small hock on to the end.
2. If the roller stops turning it can be caused by one of the power wires to the moter getting severed in the swivel connection in the head unit. This has happened to us twice. I took the unit apart (a pain) and was able to fix by soldering and taping wires. However, Hoovers design is not great in getting power to the motor and this may recur. I love these vacuums and I hope they engineer a more robust wie feeding solution.
Posted on Jan 30, 2012
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
I followed the trouble shooting advice for a Hoover steam vac that has non-spinning brushes. Turbine ordered and replaced. Female receptacle still is not spinning. What now?
There could be several reasons for this. Remember that the brushes will not turn unless the dirty water tank is in place. Also the handle must be released and tipped back. It is also possible that the rubber seal that the lower tank sits on is missing. If you look down into the motor area, there should be a large, round rubber seal that the lower tank sits on. Look for the round tube that protrudes from the bottom of the dirty water tank. This tube sits against the seal. If it is missing it will need replacement.
Jul 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steam vac spin scrub that won't pick up the dirty water heeelllllllppppppppppppp please
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Jun 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac Spin Scrub that won't pick up the water. Could you please give me some info on how I might fix it. Thanks!
I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Vacuums Logo
23 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
