Question about Emerson EWL3706 37 in. LCD Television
I have exactly the same issue with my DMTECH television. Help!
I can't access my digital channels as it shows a message asking for lock key.
My manual states that the initial password is 0000.
Posted on Jul 30, 2009
How to unlock a jcv s1465 screen
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Feb 26, 2013 | Insignia Televison & Video
Password for jvc tv v-chip
Jan 17, 2013 | Televison & Video
How to turn off clock on jvc tv
Sep 06, 2012 | JVC Televison & Video
Ondia tv ky thunder 800 all the channels are locked and it is asking password i need the password please provide me
Can you please go through the operation manual to check whether anything is mentioned about resetting using a default password key?
Aug 22, 2012 | Televison & Video
Remove the prerental block on a jvc tv
Apr 03, 2012 | JVC Televison & Video
How do I retune DMTech TV Freeview with DVD video please?
Please fallow bellows instruction to retune your TV.
Could you please follow that EEPROM RESET INSTRUCTION OR FIRST TME INSTALLATION.
Also please don’t forget that MENU BUTTON from your remote, it’s not the one in the middle of remote.
There are the other MENU BUTTON in left down bottom side.
Cannot access Digital TV and am asked for a Lock code Key?
If you cannot access the Digital TV option then conduct an EEPROM RESET as mentioned above. If you are prompted to enter a lock code key enter three / four zeros.
Alternatively when prompted to enter the lock code key conduct a FIRST TIME INSTALLATION also mentioned above.
There are two options available. The first option is to conduct a general reset that will reset all user preferences. The second option would be to conduct an EEPROM RESET. An EEPROM RESET would reset all the internal hardware.
Instructions - Please refer to your DMTECH remote control and user manual provided
1. Turn the Television ON ? Button on front of Television / Power button on remote control.
2. Make sure that you are on Analogue television by pressing the TV/DVB-T button until you see PR and the channel number selected in the top right corner of the screen, e.g. PR 1.
3. You must then Press the button labelled Display until a window titled INFORMATION is displayed on the screen.
4. Only when the window titled Information is present can you continue by pressing the digit (1) twice and then pressing the button titled LINE. If you make a mistake then press Display again to remove the window titled INFORMATION and repeat the process. (Display - 1 1 - Line)
5. Once you have successfully completed step four you will notice that a menu appears on the left of the screen. You can then select which option you want, either RESET or an EEPROM RESET using the arrow keys. To execute an instruction please use the RIGHT ARROW KEY and not the ENTER button.
Make sure you have properly conducted a FIRST TIME INSTALLATION and an AUTOMATIC SEARCH. If having done this you can try conducting a manual search in an attempt to force / lock the channel.
This will erase the DVBT tuner memory and reset the interface card. This may resolve poor channel reception, the inability to store channels or even receive certain channels.
1. Turn the Television ON and select digital television by pressing the button labelled TV / DVB-T located under the power button on the remote control.
2. On the remote control locate and press the button labelled Menu, found at the extreme bottom left of the remote control.
3. A Menu should now appear displaying options. Scroll down and select the option labelled SETTINGS using the ARROW KEYS and the enter key located in the middle of the remote control. On the next menu you must select INSTALLATION to move on to the next menu.
4. On this last menu scroll down to the last option labelled FIRST TIME INSTALLATION and select it pressing the enter key. You will then be prompted to delete all channels, using the left arrow key to select yes and press enter to execute. The television will reset and prompt you to commence an AUTO SEARCH. Follow these instructions to tune in channels.picture
Digital Television requires much more from existing aerial systems. Having more than one digital TV may reduce signal quality and strength depending on how the aerial system is set up. It is therefore recommended that if you decide to use more than one digital television you use a booster and or at least make sure you are using a digital ready aerial. Using an existing Aerial that is split may reduce signal strength depending on how many times it is split. Please see the diagram below. The best solution when using an existing aerial is to purchase a booster device. Aerial Splitting - Why a booster is recommended. A booster is used to apply a small current that boosts the existing signal. A booster can be purchased from all main TV/HI-FI - consumer electronic product retailers.
Jan 16, 2010 | Televison & Video
Dmtech 32" lcd no channels, asking for inter lock key can you help?
Had similar problem with my 20" model - here's what I did:
1. Inserted initial password which the manual states is '0000'.
2. Pressed 'Menu' on remote control.
3. Chose 'Settings'.
4. Chose 'Installation'.
5. Chose 'Automatic search'.
Hope this helps.
Jun 09, 2009 | Emerson EWL3706 37 in. LCD Television
I cannot access DTV
reinstalled all programmes
thank you
Nov 23, 2008 | Televison & Video
Sky remote code
DMTECH LCD TV SKY REMOTE CODE 1992 (REMOTE MUST BE VERSION 8 CHECK INSIDE BATTERY COVER)
Dec 17, 2007 | Televison & Video
Emerson EWL3706 37 in. LCD Television Logo
274 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
