Question about Sharp FO 4450 Laser Fax
Must pick up reciever to receive fax or it won't connect - just keeps on ringing, machine is 5 years old - has never had any problems before this. It has no model number printed on it.
    President:
  • 3,085 Answers
Check your menu settings, you are set to MANUAL MODE
Posted on Jul 30, 2009
FO-3150-won't auto answer, have to pick up receiver to get faxes
renield, that worked perfect!!! Thanks a million!
Feb 06, 2013 | Sharp Fo-3150
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
Can't receive faxes
The problem is in the recieve mode you have it set to tel/fax you need to set it to fax if yu have it on auto or te/fax if you pick the phone up you have to press the start bbutton to get the fax through if you are only using it as a fax set it to fax .. it will then go strait through.. good luck..A
Jun 27, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine won't receive without pick up phone receiver.
on the front display you will see a recieve button and you need to press this and you will see on the display it say either fax...fax/tel.. auto press the button until fax shows thsi means it is only being used as a fax so the line will auto pick up... if you set it to auto it will ring check the line and if it finds its a fax it will put it through as one if not it will ring you phone.. good luck
Jun 26, 2009 | Brother IntelliFax-4100e Fax
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
You have to answer the hone to recieve the fax
Try unplugging the power cord for 10 seconds to reset the machine.
Scroll through the menus and set your machine to AUTO or AUTO RECEIVE.
Nov 25, 2008 | Brother MFC-8220 Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Sharp FO 4450 Laser Fax Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
