Question about Sony KV-32S45 32" TV
Sonykv-32v40 red ligt blinking black screen and soud good
Sony kv-32v40 red ligt blinking black screen and sound good.what should i do about that problem
  • 934 Answers
Re: sonykv-32v40 red ligt blinking black screen and...
Take it to a shop... It's a good bet that the jungel Ic, crt driver Ic or something in the HV has failed. Could be also that the crt itself is failing. If that's the case a tech can test it with a B&K and know for certain.
Also, if you want to save a few dollars take it in to them, don't make them come and get it - it just drives the price up for a pu/del charge.
Posted on Nov 24, 2007
0 characters
3 Points
Sony kv 35s42 sound but black screen and constantly blinking stand by/timer red light
Your vertical IC will need resoldering. If you can take this board out and inspect the pins under the vertical IC, you will see rings around the IC. This is a common problem for you model of TV. Hope this a few hands of support.
Dec 14, 2010 | Sony KV-35S42 35" TV
Sony KV-32V40
I'll let you know if the user manual is available.
Jun 09, 2008 | Sony KV-32V40 32" TV
The screen stays black when the power is turned on. the stand by/timer ligt blinks
There is a high voltage, and or scan failure. This can be the flyback assembly, and or other support components. If the CRT is defective, it can cause this type of shut-down.
The cost for servicing this would be fairly expensive. It would be best to start shopping for a new set.
Jerry G.
Oct 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
KV-32V40 32" TV Problem:
Need a little information here...
1. The TV remains on with no picture, but the sound is fine?
2. How many blinks does the standby light give? Are they continuous? Is it the same each time, or random?
3. Did anything else happen before this, or did it just happen one day?
Answer that and I'll try to help with what I know.
This problem is indicative of a problem with one of three (of the same) ICs. Give me a bit more info and I'll give you some links to the solution, or help you myself.
Nov 24, 2007 | Sony KV-32V40 32" TV
No picture but sound ok
Nov 22, 2007 | Sony KV-32V40 32" TV
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Sony kv-32v40 Screen blins on and off
Increasing the screen control will not repair the problem,look for loose conections in the Horizontal driver transformer,readjustback the screen control.
Aug 25, 2006 | Sony KV-32V40 32" TV
Sony KV-32S45 32" TV Logo
77 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
