Question about GE Profile Performance 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25PPBWW
Ice dispenser has rust
I have a ge profile performance fridge. I have rust on the spiral ice dispenser in the ice holding bin. How do I remove this rust and what do I put on the spiral ice dispenser to prevent this rust from coming back?
    Problem Solver:
  • 3 Answers
The rust will conterminate your ice, please have the spiral ice dispenser replaced.
Posted on Jul 30, 2009
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water Dispenser works intermintently, Ice dispenser never works
Called GE Service Dept. My refrigerator was way out of the warrant period. They came out and replaced the main circuit board at NO CHARGE.
Jan 12, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dispenser does not dispense
SOUNDS LIKE THE MICRO SWITCH OR PC BOARD BEHIND THE LEVER IS BAD,REMOVE CHECK CHECK AND REPLACE IF NEEDED,MIKE
Sep 03, 2008 | GE Profile Arctica Stainless Steel Top...
GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Sep 24, 2007 | Refrigerators
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
367 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
