Question about Hitachi 42HDS69 42 in. Plasma Television
42HDS69 cable input is only thing working
When I got cable and programmed cable remote to work the tv, I lost menu and control of inputs. None of my inputs except for the cable input work now. I can't switch over to the dvd or any other. Anybody else experience this at all?
  • 2 more comments
  • ramta Apr 04, 2008
    I have same problem with 42HDS69. Input is stuck to HDMI. No menu shows up. Remote works but only for On-OFF and volume. No onscreen display either. This seems like a known issue.
  • ekiessel Dec 29, 2008
    I have the same issue. Only one input works and I can't access any menus.
  • daryl fuhrmann Jan 22, 2009
    I have the same problem. I have the original remote but it still will not access the menu or change inputs.
  • RTMatthews1 Feb 22, 2009
    i have a 50in hitachi plasma and the buttons on the side of the tv just stopped working except for the power button also the remote doesn;t work either
  • 30 Answers
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If youdon't have the original remote and can't find it ever then the only way to reachyour tv is through coaxial antenna port. Soyou can buy an rf modulator ( very cheap) and connect your red yellowand white cables (rca cables from a dvd, game consoleetc) to the modulator then connect the modulator to your antenna with acoax cable. This worked for me. It placed the connection to channel 4and other channels are still working,
You can buy the RF Modulator from:
Posted on Oct 15, 2008
How to find source for model WS-28W63N without the remote control
Sometimes you can unplug the hdmi cable and power off the tv and unplug power to tv wait 10 sec plug tv back in and then insert hdmi cable. Some of the newer tvs will auto tune to the input if that dont work, try getting a universal remote program the remote to control tv if you can control tv volume, power , menu then you should be able to navigate to the input menu and select hdmi that way
Jan 13, 2013 | Samsung TV Remote Control
Try pressing Tv/Video on the remote control and see if it doesn't switch input modes. If it doesn't, follow these steps:
1) Press the menu button
2) Navigate over to Channel Setup
3) Move down to Video Label and select it
4) Make sure none of the video inputs are labeled "SKIP". If so then do the following
5) Highlight the input labeled "SKIP" and select it
6) Use the up and down arrows and you should see a different name for the input. This will enable the selected input to be used.
7) Exit the menu by pushing the menu button on the remote.
8) Press Tv/Video on the remote and you should see the other stuff (cable, vcr, xbox, etc.).
Aug 15, 2010 | Sony KV-32FS13 TV
I am trying to program my Vizio Universal Remote XRU9M With my comcast cable box and none of the codes in the manual are working. We tried doing the 9-9-1 thing for the vizio remote which is a little...
Hello, Twomufflers -
Doesn't Comcast provide you with a remote to use for the cable box?
We have AT&T Uverse as our cable provider and have an AT&T remote control for each of our cable boxes.
One of our TVs is a Vizio and we only use the Vizio remote control when we need to change something through the TV menu - like when we change from HDMI input (for cable programs) to AV input to watch a DVD.
Jan 12, 2018 | One For All URC-9800 LCD Remote Control
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Jan 08, 2009 | RCA Scenium L50000 Television
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
Sep 19, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Concierge by Zenith Input Problems.
I had the same tv at my motel and wanted to hook up my Wii. Turning to Channel 999 worked.
Jan 17, 2008 | Zenith C27A24T 27" TV
Hitachi 42HDS69 42 in. Plasma Television Logo
370 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
