Trying to figure out where to charge my a/c on my 1989 ford bronco. there are two valves one by the dryer and one by the the radiator which one do i use ?
  • 2,418 Answers
Use the one by the drier. your hose that came with the freon can should only fit this one port.
Posted on Jul 30, 2009
How to do valve lash adjustments bronco ii 1989?
There are too many steps to cover here, but given the age of your Bronco, there should be ample workshop manuals on ebay, local adverts or bookshops. This is your first call.
Jun 02, 2015 | 1989 Ford Bronco II
1989 Bronco: 89 ford bronco i put a new starter new battery new...
Check the battery cables for corrosion near the battery terminal end. Sometimes it builds up under the rubber insulation. I would check the ground wire that runs from the battery to the engine block.
May 16, 2010 | 1989 Ford Bronco
I just noticed the 2 freeze out plugs came out over the winter on my 1989 ford bronco. the truck has been laid up for the winter but i am almost certain there was antifreeze in the radiator can ypou tell...
The vehicle is 21 years old. The mixture may have had more water than antifreeze in it or the system may not have been properly serviced over the years.
A little abnormal but not that uncommon.
Have the system checked out and have the cooling system pressure tested.
Mar 29, 2010 | 1989 Ford Bronco
My 1989 Ford Bronco 2 won't start. I just did a radiator flush, I left the flush with water mix sitting in my car after running for twenty minutes. The next day, the vehicle would not start. Does this have...
The coolant flush would have nothing to do with the no start as long as you didn't overheat the engine. I suggest you do a fault code test on the engine control module, it is called an EECIV KOEO fault test. The instructions are at the link. EEC IV Self Test Ford Fuel Injection and EEC IV Electronic Engine Control...
May 10, 2017 | 1989 Ford Bronco II
Inner body parts, front end where the radiator and AC condenser is bolted to.
http://www.lmctruck.com/icatalog/fd/t.aspx?Page=2
Check out this site, they have a lot of stuff for your Bronco II.
Aug 25, 2009 | 1989 Ford Bronco II
A/c chargeing
There should be a little valve that looks like a tire valve on the refrigerant line. This is the nozzle to fill with R12
Jul 29, 2009 | Heating & Cooling
Engine idles to fast and runs rough
you can check timing, or check for vacuum leaks
Oct 12, 2008 | 1989 Ford Bronco
1989 BRONCO XLT WITH A 5.8 351 CLEAVLAND
The Bronco did come with the 5.8L. It's a 351 Windsor though. Ford quit making the Cleveland engine back in '74. You should have a vacuum diagram under the hood of your truck.
Aug 11, 2008 | 1989 Ford Bronco
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
