Lands Phones Logo
Tinny Bryant Posted on Feb 10, 2018
How do I access my voice mail
DECT 6.0.
5 Related Answers
Anonymous
  • Posted on Jun 23, 2008
SOURCE: Voice Mail
If you go to Menu/Messages/Delete Msg, it should take care of it.
Anonymous
  • Posted on Aug 12, 2008
SOURCE: GE MODEL 28811 DECT 6.0
I have this same problem. Still don't know how to fix it.
jlai
  • Posted on Dec 03, 2008
SOURCE: can not access the voice mail. can not leave voice mail.
Just need to power off and on the system.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Anonymous
  • 34 Answers
  • Posted on Jul 02, 2009
SOURCE: My phone says I have a voice mail message.
dial *98
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
VM access
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voice mail access code and press [SAVE].
How do I set up voice mail for my uniden 6.0 without answering system
If you do not have an answering system (answering machine) on the phone, you need to purchase a answering machine or contact your telephone service provider to get Voice Mail service from them. (Most charge $3-5 per month for voice mail.) The provider will tell you what number to call to set up a voice mail message and access messages.
I hope this helps.
(for most Uniden systems with the answering system, you need to turn it on and then access the system from the handset to set the out-going message and length of incoming messages allowed.)
How do I retrieve my voice mail from my uniden dect 6.0?
If you have an Uniden answering machine, select it from the list beginning here to download a copy of the manual. If the voicemail is on the voicemail system provided by your telephone company, contact them for instructions on accessing their system.
If you require further assistance, please specify the model of your Uniden DECT 6.0 system.
How do I retrieve voice mail messages from my uniden dect 6.0?
LED on the handset flashes and appears in the handset display whenever you have messages waiting in your
1helpful
2answers
Uniden dect 6
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only suggest that you select it from the list beginning here to download a copy of the manual.
I get my message to voice mail not to my answering machine at home. why
your service provider might come with voice mail system, you need to log on to your provider website and disable the voice mail or you can setup your provider voice mail to 4, 6 sound and your Digital Cordless to 2 sound before the voice mail pick up and you will see the difference.
1helpful
Listen to voice mail
Those messages are on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Top Dect Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Dect Lands Phone Expert? Answer questions, earn points and help others
