Code for programming a VCR Durabrand DBV4403 to ExpressVu satellite
Code 009 was successful in programming the Durabrand DBV4403 VCR to Bell ExpressVu receiver 3100.
Posted on Jul 31, 2009
Getting VCR to record from Bell Express View
try this website
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.doc
keep scrolling down in the list until you find the vcr codes.
i found the 3 digit code for my sony VCR. it gave me several codes, but i finally found the one that worked with my bell expressvu.
good luck
Jan 29, 2009 | Televison & Video
Codes to program Innovage Products Jumbo Universtal Remote
Innovage Jumbo remote codes for RCA TV; 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191,194.
Pansonic DVD; 175.
Pansonic VCR; 021, 060, 115, 125, 138, 148, 149.
Philips DVD; 173, 183, 198.
Bell ExpressVu; 168, 187, 194.
Dec 18, 2008 | Televison & Video
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
Nov 17, 2008 | RCA Universal Remote Control
Samsung BP59-00071B remote wont program Sanyo VCR DVD combo
Try 543. thats what I need to record to my Sanyo VCR via Bell ExpressVu satellite receiver.
Nov 11, 2008 | Televison & Video
I have an RCA universal remote and I need a code for a Bell ExpressVu satellite in order to use the remote for both my TV and Satellite.
004 was the only code I could find for Bell but i do not think it will work. Therefore, i recommend the following:
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 26, 2008 | Televison & Video
Toshiba DVD/VCR Recorder
The only thing you can do is to program the recorder to come on and record at a certain time and also program the event timer for the Bell Expressvu.
Mar 13, 2008 | Televison & Video
Try this site;
http://www.blurtit.com/q717681.html
Good luck
Mar 03, 2008 | Televison & Video
Code for satellite bell (expressview)
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 03, 2008 | Televison & Video
No code for expressvu
If you have tryed the auto searce mode, that means you tryed every code inside the remote, and if it didnt hit, Im sorry to say your out of luck, as this remote, as I understand from the spec sheet, is not a programmable or learning type remote.
Aug 06, 2006 | Jensen JR400 Remote Control
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
