Question about iLO DVDR04
Tray wont open and tuner seems not to work
My DVDR04 wont open. It seems to be hitting against something but i cant figure out what and the tuner isnt working for some reason. and i cant see if the drive will not record because i cant get a disk into it
    Problem Solver:
  • 16 Answers
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Posted on Aug 09, 2009
How do I get the tray to stay closed on my iLO DVDR04
This is normally caused by a small loading belt that has stretched and the tray can not complete the cycle to close the door properly thus causing it to open.
Apr 19, 2012 | iLO DVDR04
Ilo dvdr04 tray drive belt
take thebelt out and clean it first, sometimes they get contaminated with grease
Mar 01, 2008 | iLO DVDR04
Dvd drawer keeps opening up on its own and will not stay shut?
There is a switch located at the front of the player right under the DVD tray. This switch tells the player that the door is completely closed. If this switch does not operate, then the Ilo will re-open the DVD tray thinking that something is jammed. Might want to try replacing that switch
Dec 29, 2009 | iLO DVDR04
My xbox 360s isn't working
In very rare instances I believe that the dvd drive of your xbox 360 might have been disconnected.In this case,it dispays an "open tray" message.For this you will have to open your 360 but please take it to the dealer if you are still protected by warranty.Good luck.Thanks for reading.
Jun 18, 2009 | Microsoft Xbox 360 Console
Tray will not open
take of the screws and see if the drive belt is broken or if it just fell off and to be honest you dont need to buy a belt the right size rubberband will work just the same .. i have done it
May 28, 2009 | iLO DVDR04
Tray Wont open
Hello All. Well, I just finished troubleshooting the same problem of one of my customers units. At first I thought it was the tray contacts but they were good. What I noticed with the cover off and the shield for the laser removed...BE CAREFUL NOT TO BREAK IT TAKING IT OFF ANF DON"T LOOK AT THE LASER...that if I moved the DVD motor, the motor that turns the DVD...it has a rubber wheel on the shaft...that the tray would open. The trouble was intermittent but I also noticed that the wheel would move when pressing the OPen button. I therefore concluded that the motor somehow was in the circuit to open the tray. So, I took the motor out CAREFULLY and on the end opposite the wheel there are two small holes. These holes appear to be access holes for assembly and to hold the brush contacts away from whatever they use for a commutator. At first i was going to disassemble the motor but changed my mind. I have contact cleaner spray and some old Color Tuner Cleaner spray from the old days of mechanical TV tuners. I gave each hole a small shot of spray and turned the wheel. Careful not to contaminate the rubber on the wheel as it is what grips the DVD and pushes it against the white nylon bearing. Voila, the tray opens and closes and the Load display is no more. As I said, be careful. If you are unsure...let someone who understands this stuff do it. Ed
Jun 13, 2008 | Samsung DVD-V4600 DVD Player/VCR
Tray will not open
My ILO was doing the same thing, then it stopped doing it. It then suddenly would not recognize any media. I opened up the case and found it is using a dvd lite-on recorder. I had this old pc laying around with a gigabyte dvd recorder in it. For a test, I unplugged the lite-on and plugged in the gigabyte recorder. On power up, it seemed to work fine. After recording 3 DVD's I modified the case to accept the hew recorder. ** problems since, its not pretty, but it was easy to get the unit functional again.
Jan 13, 2008 | iLO DVDR04
DVD tray will not remain closed
Try this. With the tray door still open and the power on, press and hold the play button until the door closes. If you hear the disc loading the door will remain closed for play and record.
Have the same problem - works for me!
Dec 15, 2007 | iLO DVDR04
Lcd
What probably happened is your backlight went out on your LCD. If it is still covered under a warranty they would replace that. But there aren't any buttons you can push to get it back. You'll have to replace the screen.
Jul 18, 2007 | Samsung Digimax Pro 815 Digital Camera
iLO DVDR04 Logo
409 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
